0 Replies Latest reply on May 6, 2010 11:05 AM by Chet Haase
    [svn:fx-trunk] 15923: Initial checkin of "Transition Interruption" feature.
    Chet Haase Level 3
      Revision: 15923
      Revision: 15923
      Author:   chaase@adobe.com
      Date:     2010-05-06 11:05:24 -0700 (Thu, 06 May 2010)
      Log Message:
      Initial checkin of "Transition Interruption" feature. Set Transition.interruptionBehavior="stop" to get the new behavior, where interrupting transitions start from where the previous transition is at, rather than end()'ing the previous transition first. The default behavior is the same as it always was; transitionBehavior="end" is the default property, and that uses the previous behavior of ending the previous Transition.
      New API: Transition.interruptionBehavior, mx.states.InterruptionBehavior
      QE notes: Check out the spec for the details on the new API
      Doc notes: none
      Bugs: none
      Reviewer: Jason
      Tests run: checkintests, Mustella (mx/effects, spark/effects)
      Is noteworthy for integration: Yes - feature requested by downstream teams
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/CompositeEffect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/Transition.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Fade.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateInstance .as
          flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/InterruptionBehavior.as
