6 Replies Latest reply on May 6, 2010 2:07 PM by hrggroup
    text in illustrator
    hrggroup Level 1
      Hello,
      Am hoping someone can help me with this. I am still using Illustrator 10.
      I am trying to make text look boxed, but I imported the text from a word
      document.  Not sure what I am doing wrong.  When I go to Effects, Convert
      To Shape then Apprearance the text disapears.  I did select the text before
      doing all these steps.
      What am I doing wrong?  Do I need to type the text instead of importing it?
      Thanks in advance for anyones help.
        • 1. Re: text in illustrator
          Larry G. Schneider Adobe Community Professional & MVP
          You will need to add a New Stroke or Fill from the Appearance panel flyout, make sure that line is highlighted in the Apperance panel and then use Effect>Convert to Shape>Rectangle to get the result you want
          • 2. Re: text in illustrator
            hrggroup Level 1
            Thank you.
            I think that was not what I was looking for.  Probably margins is what I am meaning to
            ask about.  That all the text is evenly ligned on the left and right.  Is that what I need to do?
            Thank you again.
            example:
                 aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
            aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
            aaaaaaaaaaaaaaaaaa
            aaaaaaaaa
            not:
            aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
            aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
            aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
            • 3. Re: text in illustrator
              Then you need to use the Text tool to draw a box and insert the test. Select it with the Selection tool and from Window>Type>Paragraph select the middle box.
              • 4. Re: text in illustrator
                hrggroup Level 1
                Great!! Thank you!
                One last thing, how do I correct the spacing?
                It looks like this (well not that far apart but pretty much):
                aaaaaaaaaaa
                instead of:
                aaaaaaaaaaaaa
                • 5. Re: text in illustrator
                  In the Character panel look at the leading
                  • 6. Re: text in illustrator
                    hrggroup Level 1
                    Got it!  Thank you!
