1 Reply Latest reply: Sep 1, 2007 11:41 AM by Robert Reinhardt RSS
    flash video will work, right?
    Nickels55 Community Member
      Dreamweaver helps, but it is not necessary. You can hand code everything in notepad if you had to. The main thing you need is something to convert the video to flv format. It also makes it easier if you place that file in flash and output a swf file for the web with a controller skin.
      If your customers use a 56k modem, then the video will not really work for them. Flash video works best on high speed connections. The size is up to you. I found that 480x360 at medium compression works pretty good for the web.
