4 Replies Latest reply on May 10, 2010 11:02 AM by ssardar
    Web Service Result Handling
    ssardar Level 1
      I'm new to flex and was looking for the best way to display my web service result in AdvancedDataGrid.
      Could someone please take the time to spellout how to do this.
      I have tried it using the MXML approach and the AS code...I keep thinking I am missing something.
      Basically I am returning an Array of a custom defined Object,.  Everything in the object is a string, so it's not overly complex.
      I'm certain my service is returning a response as I have checked it with soapUI.
      So how do I map this result over to a ArrayCollection??
      <mx:WebService id="srv" wsdl="wsDest"
      <mx:operation name="getGridData"
      fault="showErrorDialog(event)"
      result="somefunction(event)"
      </mx:operation>
      </mx:WebService>
      <mx:Script>
      <![CDATA[
      import mx.rpc.soap.SOAPFault;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.events.FaultEvent;
      import mx.controls.Alert;
      import mx.collections.ArrayCollection;
      Bindable]
      public var myArray : ArrayCollection = new ArrayCollection();
      public function log(event:ResultEvent):void {
      // Handle result.
      myArray = ArrayCollection(event.result);
      trace(event.result);
      </mx:Script>
      My current error:
      Error #1088: The markup in the document following the root element must be well-formed.
      So am I forgetting something?  Do I need to strip out the SOAP Headers?  Any Ideas?
      I've tried the above approch amongst others...but would like someone to spell out a definitive approach to this.  Any help is greatly appreciated, thanks in advance.
        • 1. Re: Web Service Result Handling
          Marcello Rego
          Hello. Down i put a example of websevice usage. First you have to use a valid wsdl parameter, and the result is by default in a XML format. This code will show this.
          <mx:WebService id="service"
               wsdl="http://wslite.strikeiron.com/phonenumberinfolite01/PhoneNumberInfoLite.asmx?WSDL">
          <mx:operation
               name="GetLocationInfoForPhoneNumber"
               result="result(event)"
               fault="fault(event)"/>
          </mx:WebService>
          <mx:Script>
          <![CDATA[
          import mx.utils.ObjectUtil;
          private function search():void
          service.GetLocationInfoForPhoneNumber(areaCode.text, threeDigits.text);
          private function result(e:ResultEvent):void
          Alert.show(ObjectUtil.toString(e.result));
          private function fault(e:FaultEvent ) : void
          Alert.show(e.fault.message);
          </mx:Script>
          • 2. Re: Web Service Result Handling
            Radhakrishna Bhat Level 3
            Can you re-check your WSDL file/SOAP response? there must not be any unclosed tags.
            -Radhakrishna
            • 3. Re: Web Service Result Handling
              Marcello Rego Level 1
              Sorry.
              I put below a new example of Webservice usage.
              The first question and problem is that the ArrayCollection creation parameter was wrong. You must especify it like that
              new ArrayCollection(e.result.toArray());
              Example:
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
                  <mx:Script>
                  <![CDATA[
                      import mx.collections.ListCollectionView;
                      [Bindable]
                      private var categories:ListCollectionView = new ArrayCollection();
                          service.getCategories();
                          categories = e.result as ListCollectionView;
                  </mx:Script>
                      wsdl="http://feeds.adobe.com/webservices/mxna2.cfc?WSDL">
                      <mx:operation
                           name="getCategories"
                  </mx:WebService>
                  <mx:Button label="GET CATEGORIES" click="search()"/>
                  <mx:DataGrid dataProvider="{categories}">
                      <mx:columns>
                          <mx:DataGridColumn dataField="categoryId" headerText="ID" />
                          <mx:DataGridColumn dataField="categoryName" headerText="NAME" />
                      </mx:columns>
                  </mx:DataGrid>
              </mx:Application>
              • 4. Re: Web Service Result Handling
                ssardar Level 1
                Marcello,
                  Thank you, these two items were key.  It works correctly now.  Thanks again.
