6 Replies Latest reply on May 8, 2010 2:10 AM by sandymojo
    Setting up HDD
      Hi Friends,
      What would be the best HDD setup specifically for Adobe After Effects CS3
      I have got:
      - 1 Intel Extreme X-25 SSD. (34GB)
      - 1 WD VelociRaptor 10000 RPM (150 GB)
      - 1 Seagate Baracuda 7200 RPM (500 GB)
      Can buy one more disk if really required
      For backups i have Seagate Freeagent.
      How should i assign these disks. I mean which disk for which task ?
        • 1. Re: Setting up HDD
          Andrew Yoole MVP & Adobe Community Professional
          Use the SSD as your System drive, with OS and applications on it.
          Use the 10000RPM drive for primary storage of current jobs - project files, footage items, disk cache etc.
          Use the 7200RPM drive as secondary storage for jobs in progress.
          • 2. Re: Setting up HDD
            sandymojo Level 1
            Thanks Andrew, for helping me out.
            I was thinking of using separate HDD for scratch disk.
            Is it advisable to use 7200RPM for scratch.
            And If I choose to put my applications/softwares too on separate disk
            which new HDD will you recommend me to buy.
            • 3. Re: Setting up HDD
              It depends on your workflow and resources.  If you're using uncompressed 1080p footage, every bit of drive speed will help, so stick to 10000RPMs.  But if you're working in Standard def and/or with compressed video, the difference in AE between your 10000 and 7200 RPM drives will be negligible.
              Personally, I use multiple 7200RPM drives in a RAID configuration to give me better drive performance at low prices.  3 x 1.5 TB Seagate drives have the capacity and speed to capture uncompressed 1080, but cost about US $300 in total.
              • 4. Re: Setting up HDD
                sandymojo Level 1
                On a slightly different note. I'm looking for smooth scrubbing previews & overall fast workflow while i'm working on 1080p compositions in AE CS3. I don't want hang ups & don't want to wait for the layers to adjust slowly as i progress with my project. I think its more important than faster rendering, it'll save my time & help me to complete my projects faster.
                Can you tell me which hardware/component is mainly responsible for this ?
                • 5. Re: Setting up HDD
                  In my opinion, in order of importance:
                  Hard Drives
                  GPU/Display card
                  The fastest CPU(s) money can buy will give you the best AE performance.  Multiple processors and cores also help, but raw speed is the most important factor.
                  Using OpenGL while scrubbing can dramatically speed up performance in some instances, but slow speeds in others.  So don't spend a fortune on the latest and greatest display card.  A  mid-priced GPU will do everything After Effects is capable of using.
                  • 6. Re: Setting up HDD
                    sandymojo Level 1
                    Thank You Andrew, for all your inputs & answering my queries.
                    Its really helped. Thanks again.
