1 Reply Latest reply on Dec 9, 2010 8:17 PM by Shongrunden
    Transitions is messed up the first time it runs
    nikos101 Level 2
      In the following code when the need to register button is pressed the transitions is messed up the first time it runs
      <?xml version="1.0" ?>
      <!-- transitions\LoginFormTransition.mxml -->
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     xmlns:s="library://ns.adobe.com/flex/spark">
          <!-- The Application class states property defines the view states.-->
          <s:states>
              <s:State name="default"/>
              <s:State name="Register"/>
          </s:states>
          <!-- Define the transition to animate the change of view state. -->
          <s:transitions>
              <s:Transition fromState="default">
                  <s:Parallel>
                      <mx:Resize target="{loginPanel}" duration="500"/>
                      <s:Wipe direction="right" target="{confirm}"/>
                  </s:Parallel>
              </s:Transition>
              <s:Transition fromState="Register">
                  <s:Sequence>
                      <mx:Resize target="{loginPanel}" duration="100"/>
                  </s:Sequence>
              </s:Transition>
          </s:transitions>
          <!-- Set title of the Panel container based on the view state.-->
          <s:Panel id="loginPanel"
                   title="Login" title.Register="Register">
              <s:layout>
                  <s:VerticalLayout/>
              </s:layout>
              <mx:Form id="loginForm">
                  <mx:FormItem label="Username:">
                      <s:TextInput/>
                  </mx:FormItem>
                  <mx:FormItem label="Password:">
                      <s:TextInput/>
                  </mx:FormItem>
                  <!-- Add a TextInput control to the form for the Register view state. -->
                  <mx:FormItem id="confirm" label="Confirm:" includeIn="Register">
                      <s:TextInput id="myTI"/>
                  </mx:FormItem>
                  <mx:FormItem direction="horizontal" >
                      <!-- Use the LinkButton to change to the Register view state.-->
                      <!-- Exclude the LinkButton from the Register view state.-->
                      <!-- Add a LinkButton to the form for the Register view state. -->
                      <mx:LinkButton label="Return to Login"
                                     click="currentState=''"/>
                      <mx:Spacer width="100%" id="spacer1"/>
                      <!-- Set label of the control based on the view state.-->
                      <mx:LinkButton id="registerLink"
                                     includeIn="default"
                                     label="Need to Register?"
                                     click="currentState='Register'"/>
                      <s:Button id="loginButton"
                                label="Login" label.Register="Register"/>
                  </mx:FormItem>
              </mx:Form>
          </s:Panel>
      </s:Application>
