7 Replies Latest reply on May 10, 2010 4:55 PM by kglad
    Flash CS4 and XML
    larellG
      I'm using Flash CS4,i'm having problems creating a xml file to work
      with the action script for a 3D carousel. I've created folder for
      the image png file and icons xml using a normal notepad in windows
      for file to work with the flash action script 2.0, but in output menu the msg says
      Error opening URL 'file:///C|/Users/User/Documents/caroselFile/icons.xml'.
      They're no compiler errors. Should the notepad be xml editor? I have been
      told i can use a normal notepad.
      Maybe i should of saved it in the fla directry but don't know where
      it is.
      Thanks Larell
        • 1. Re: Flash CS4 and XML
          show your xml file.
          • 2. Re: Flash CS4 and XML
            larellG Level 1
            <icons>
            <icon image="icon1.png" tooltip="" />
            <icon image="icon2.png" tooltip="" />
            <icon image="icon3.png" tooltip="" />
            <icon image="icon4.png" tooltip="" />
            </icons>
            Message was edited by: larellG
            • 3. Re: Flash CS4 and XML
              why are you using an absolute path to your xml file?
              • 4. Re: Flash CS4 and XML
                larellG Level 1
                I dont know, thats what i thought flash tutorial instructed me to be to do. So what do i do? Please.
                • 5. Re: Flash CS4 and XML
                  you can use an absolute path but the chances of an error are much greater than when using a local path.  in addition, your absolute path won't work as soon as you deploy your swf (on a server or as an air or as a projector file).
                  use a relative path.  the easiest is to put the xml file in the same directory with your html, swf and fla.  you can then use:
                  yourxml.load("icons.xml");
                  i like to keep xml files in an xml subfolder of the folder that contains my html,swf and fla.  in that situation you would use:
                  yourxml.load("xml/icons.xml");
                  but whenever you have a path problem, the best bet after a few checks and rechecks of spelling is to put the file to be loaded in the same directory as all the flash files and make sure you can get that working.  then start moving files to create a cleaner more logical setup, if that suits your needs.
                  • 6. Re: Flash CS4 and XML
                    larellG Level 1
                    I will try that thanx
                    Date: Mon, 10 May 2010 15:30:04 -0600
                    To: larell@live.co.uk
                    Subject: Flash CS4 and XML
                    yoururlloader.load("icons.xml");
                    yoururlloader.load("xml/icons.xml");
                    • 7. Re: Flash CS4 and XML
                      you're welcome.
                      p.s.  please mark this thread as answered, if it is.
