5 Replies Latest reply on May 9, 2010 7:27 AM by kglad
    problem with order
    newcmr.hu
      Hi!
      I made an xml driven picture gallery. My problem is that somehow the script puts the thumbnails in a reversed order, and I can't find why. Maybe it is a very small and obvious problem, but I think I have been doing it for soo long that I can't see the program. The code is:
      // ////////////////// A terület méretének meghatározása ahol látszik a kép.
      var kepXmax = 600;
      var kepYmax = 405;
      // ////////////////// A betöltő mc x-y pozíciója
      kezdoX = 100;
      kezdoY = 50;
      p = 0;
      var w = 0;
      xml = new XML();
      xml.ignoreWhite = true;
      xml.onLoad = loadXML;
      xml.load("images.xml");
      function loadXML(loaded) {
          if (loaded) {
              xmlNode = this.firstChild;
              image = [];
              description = [];
              thumbnails = [];
              cat = [];
              total1 = xmlNode.childNodes.length;
              ///////////////////////As első alkalommal az első kategóriát állítjuk be
              if (category == undefined) {
                  category = xmlNode.childNodes[0].childNodes[3].firstChild.nodeValue;
              for (i=0; i<total1; i++) {
                  if (xmlNode.childNodes[i].childNodes[3].firstChild.nodeValue == category) {
                      image[w] = xmlNode.childNodes[i].childNodes[0].firstChild.nodeValue;
                      description[w] = xmlNode.childNodes[i].childNodes[1].firstChild.nodeValue;
                      thumbnails[w] = xmlNode.childNodes[i].childNodes[2].firstChild.nodeValue;
                      cat[w] = xmlNode.childNodes[i].childNodes[3].firstChild.nodeValue;
                      prevWidth = 0
                      prevX =110
                      thumbnails_fn(w);
                      w++;
              total = w;
              firstImage();
          } else {
              content = "A fájl betöltése sikertelen!";
      listen = new Object();
      listen.onKeyDown = function() {
          if (Key.getCode() == Key.LEFT) {
              prevImage();
          } else if (Key.getCode() == Key.RIGHT) {
              nextImage();
      Key.addListener(listen);
      previous_btn.onRelease = function() {
          prevImage();
      next_btn.onRelease = function() {
          nextImage();
      this.onEnterFrame = function() {
          filesize = picture.getBytesTotal();
          loaded = picture.getBytesLoaded();
          preloader._visible = true;
          if (loaded != filesize) {
              preloader.preload_bar._xscale = 100*loaded/filesize;
          } else {
              preloader._visible = false;
              if (picture._alpha<100) {
                  picture._alpha += 10;
              szelesseg = picture._width;
              magassag = picture._height;
              presel();
      function nextImage() {
          if (p<(total-1)) {
              p++;
              if (loaded == filesize) {
                  picture._alpha = 0;
                  picture.loadMovie(image[p],1);
                  desc_txt.text = description[p];
                  picture_num();
      function prevImage() {
          if (p>0) {
              p--;
              picture._alpha = 0;
              picture_num();
      function firstImage() {
              picture._alpha = 0;
              picture.loadMovie(image[0],1);
              desc_txt.text = description[0];
              picture_num();
              presel();
      function picture_num() {
          current_pos = p+1;
          pos_txt.text = current_pos+" / "+total;
      function thumbNailScroller() {
          // bélyegképek kódja
          this.createEmptyMovieClip("tscroller",1000);
          scroll_speed = 10;
          tscroller.onEnterFrame = function() {
              if ((_root._ymouse>=thumbnail_mc._y) && (_root._ymouse<=thumbnail_mc._y+thumbnail_mc._height)) {
                  if ((_root._xmouse>=(hit_right._x-40)) && (thumbnail_mc.hitTest(hit_right))) {//a hitright ellenőrzi, hogy a thumbnail_mc még mindíg tart a hit_left alatt, nehogy túlscrollozzuk
                      thumbnail_mc._x -= scroll_speed;
                  } else if ((_root._xmouse<=(hit_left._x+40)) && (thumbnail_mc.hitTest(hit_left))) {
                      thumbnail_mc._x += scroll_speed;
              } else {
                  delete tscroller.onEnterFrame;
      function thumbnails_fn(k) {
          thumbnail_mc.createEmptyMovieClip("t"+k,thumbnail_mc.getNextHighestDepth());
          tlistener = new Object();
          tlistener.onLoadInit = function(target_mc) {//Ha betöltődött akép és lehet manipulálni
              target_mc._x = prevWidth+prevX
              prevWidth = target_mc._width+5
              prevX = target_mc._x
              target_mc.pictureValue = k;
              target_mc.onRelease = function() {
                  p = this.pictureValue-1;//mivel a nextImage hozzáad egyet a p értékéhez
                  nextImage();
              target_mc.onRollOver = function() {
                  this._alpha = 50;
                  thumbNailScroller();
              target_mc.onRollOut = function() {
                  this._alpha = 100;
          image_mcl = new MovieClipLoader();
          image_mcl.addListener(tlistener);
          image_mcl.loadClip(thumbnails[k],"thumbnail_mc.t"+k);//betöltjük a movieclip-be a képet, majd meghívjuk a fentebbi onLoadInit-t
      // ///////////////////////////// A képek scalezéséért felel
      function presel() {
          if ((szelesseg>kepXmax) || (magassag>kepYmax)) {
              // /// Ha a kép valamelyik oldala > mint a maximális (kepXmax,kepYmax)
              xoldal = szelesseg-kepXmax;
              yoldal = magassag-kepYmax;
              if (xoldal>yoldal) {
                  aranyx = kepXmax/szelesseg;
                  picture._width = aranyx*szelesseg;
                  picture._height = aranyx*magassag;
                  kozepre();
              } else if (yoldal>xoldal) {
                  aranyy = kepYmax/magassag;
                  picture._width = aranyy*szelesseg;
                  picture._height = aranyy*magassag;
                  kozepre();
          } else if ((szelesseg<kepXmax) || (magassag<kepYmax)) {
              // // Ha a kép valamelyik oldala kisebb mint a maximális
              xoldal = kepXmax-szelesseg;
              yoldal = kepYmax-magassag;
                  kozepre();
                  kozepre();
      function kozepre() {
          // ////////// Az új méretek alapján teszi mindig középre a képet
          picture._x = kezdoX+(kepXmax-picture._width)/2;
          picture._y = kezdoY+(kepYmax-picture._height)/2;
      Sorry, but the comments are in hungarian. Where I put the thumbnails is this part (this is where something goes wrong and they are placed in a reversed order):
                   nextImage();
                   this._alpha = 50;
                   this._alpha = 100;
        • 1. Re: problem with order
          it doesn't look like you're specifying any order.
          you're calling thumbnail_fn() "sequentially" but that's not related to the order in which they complete loading and your onLoadInit() is called (and it's that order that determines the thumb's positioning).
          • 2. Re: problem with order
            newcmr.hu Level 1
            Thanks for your reply!
            Aha. I tought that the prpoblem is somewhere there. Do you ha
            ve any suggestions, how I could determine that the first thumb should be placed first and then the second etc.
            My problem is that it does exactly the opposite now, and I can't make out the how to influence the order.
            • 3. Re: problem with order
              you should load them sequentially.  it looks a lot better (when you view non-instant loading), in addition, to allowing the positioning you want:
              var kepXmax = 600;
              var kepYmax = 405;
              kezdoX = 100;
              kezdoY = 50;
              p = 0;
              var w = 0;
              xml = new XML();
                  if (loaded) {
                      image = [];
                      description = [];
                      thumbnails = [];
                      cat = [];
                              w++;
                      total = w;
              prevX=110;
              prevWidth=0;
              thumbnails_fn(0);
                      firstImage();
                  } else {
                      prevImage();
                      nextImage();
                  prevImage();
                  nextImage();
                  } else {
                      presel();
                  if (p<(total-1)) {
                      p++;
                          picture._alpha = 0;
                          picture_num();
                  if (p>0) {
                      p--;
                      picture._alpha = 0;
                      picture_num();
                      picture._alpha = 0;
                      picture_num();
                      presel();
                  current_pos = p+1;
                  scroll_speed = 10;
                      } else {
                          nextImage();
                          this._alpha = 50;
                          this._alpha = 100;
              function presel() {
                          kozepre();
                          kozepre();
                          kozepre();
                          kozepre();
              kvar = k;
                       target_mc.pictureValue = kvar;
                           nextImage();
                           this._alpha = 50;
                           this._alpha = 100;
              kvar++;
              if(kvar<total){
              thumbnail_fn(kvar);
              • 4. Re: problem with order
                newcmr.hu Level 1
                Thanks very much! Now it works correctly.
                • 5. Re: problem with order
                  you're welcome.
