3 Replies Latest reply on May 7, 2010 8:48 AM by kglad
    Does nobody know?
    AllyPugh Level 1
      I posted this query
      http://forums.adobe.com/thread/632721?tstart=0
      I have had no response as yet. Surely somebody knows?
        • 1. Re: Does nobody know?
          there's never a reason to assign a variable to a textfield and it should be avoided.
          that said, cs4 has a variable field in the properties panel just like previous versions of flash (when using as2).
          • 2. Re: Does nobody know?
            AllyPugh Level 1
            Thanks for the response!
            I'm following this one frame Preloader tutorial http://www.flzone.com/go?7935
            Its asks me to name the variable.
            I think it may be my copy of Flash, I have no option in the properties inspector to label a 'Var'.
            Is there a way to label it in the AS?
            Or do you know another full proof simple preloader tutorial? I want the whole swf. to load before launching the content for the viewer you see. I've tried a load of tutorials and none are working withought using 10-15 frames at the beginning of the timeline. I only have 1 frame to put it in
            • 3. Re: Does nobody know?
              you can use anybody's tutorial but i'd be suspicious of any that used a textfield variable.  that person is very flash-savvy.
              instead of using a textfield variable, assign your textfield an instance name use use its text property instead of the associated variable.  ie, everyplace you see:
              tfVar  // where tfVar is the textfield's variable
              use
              tf.text  // where tf is the textfield's instance name.
