4 Replies Latest reply on May 8, 2010 5:00 AM by -BoNzO-
    Vector issue with generated getter/setter
    -BoNzO- Level 2
      Let's say I have the following interface and implementor :
      [Bindable]
      public interface ICar
          function get parts() : Vector.<DisplayObject>;
      public class Car implements ICar
          [Bindable]
          public var parts : Vector.<DisplayObject>;
      This works perfectly for any type other than vector. As you know, the compiler will generate the getter/setter from the default Bindable tag and the class members will successfully match the interface. I could declare a getter and a setter in the implementor but I like to keep my code simple and short and thus want to keep using this approach for simple cases.
      When using vector.<anything> though, I either get a "the class does not implement the interface correctly" or just a generated code error.
      It seems the generated getter/setter is using the wrong type ( * instead of Vector in that case ):
      [Bindable(event="propertyChange")]
      public function get parts():*
          return this._106437344parts;
      is that a known issue ?
      Alex.G
