8 Replies Latest reply: May 18, 2010 8:01 AM by John Nez RSS
    How to reduce PDF export size of Indesign documents?
    John Nez Community Member
      I wonder if there is any way for Indesign to reduce the page size of a multi-page document?
      I have a 38 page book that has a page size of 9" x 8"... so the spread size is 9" x 16".
      I want this in order to reduce the size of the exported PDF.
      So if there's a way to reduce the PDF size, that would work too.
      I've searched everywhere, but can't find a feature that allows one to reformat and save this document at a 50% reduction, for instance.
      Is there such a feature with Indesign on CS1? (or any of the more recent CS versions?)
      Right now the smallest PDF I can export of this document is 8 MB. (it contains lots of graphics)
      I want to get that figure down to 3 MB or so.
      I have the dpi all reduced to 72 dpi... which helped reduce the PDF down from the initial 58 MB.
      But how is it possible to make it even smaller for emailing?
      Thanks for any suggestions.
        • 1. Re: How to reduce PDF export size of Indesign documents?
          Peter Spier CommunityMVP
          YOu cannot change the page size when exporting  PDF.  Do you have a full version of Acrobat? If so, try using the optimizer. You can run a space usage audit first to see what's using most of the space.
          • 2. Re: How to reduce PDF export size of Indesign documents?
            Dov Isaacs Employee Hosts
            At a certain point, there is a fundamental disconnect between the concept of a graphically-rich document and wanting it to be miniscule in size. You can't have your cake and eat it too, so to speak. If by mucking with the compression and resolution settings, you've got it down to 8MB from 58MB, you've done quite well. 8MB is not that big for e-mailing of a graphically rich document. At 72dpi, your raster graphics may already be highly degraded depending upon the original content and the magnification at which the content will be viewed. If some of your graphics are vector based, the resolution and compression are irrelevant. You could conceivably make low resolution raster images out of such graphics at the cost of quality.
                      - Dov
            • 3. Re: How to reduce PDF export size of Indesign documents?
              macinbytes Community Member
              If you want 3mb with that many pages that is image intense about the only way to do it is to save out the whole layout at jpeg2000 and build the pdf from that. It will be plenty crunchy on type, but hit your size threshold. Assuming you have Acrobat you could index the document, make it searchable and replace the raster pages to get the benefit of a searchable document.
              That will also make it incompatible with Mac OS X's preview and about anything that isn't Acrobat.
              Alternately you could rebuild the layout and make flat backgrounds with type on the front of them, but you are still gonna get crunchy images on zoom.
              Why not just host it somewhere like google docs or something comparable? Emailing pdfs all over the place just bloats email servers.
              • 4. Re: How to reduce PDF export size of Indesign documents?
                Thanks for the great suggestions... much appreciated!
                jn
                • 5. Re: How to reduce PDF export size of Indesign documents?
                  Mr. Met Community Member
                  I agree about the disconnect between quality and size on graphically heavy docs. May be a case of pushing clients towards swf clients if size is that crucial to final art delivery.
                  I'm doing a pitch deck for a client. He prints x number to take to his pitches and he emails PDFs to others. Constantly complaining about 4.3MB PDFs on a 31 page documents with dozens of photos and logos and a custom built AI map that is 4.3MB by itself. You can only optimize so much without defeating the purpose of a document that relies on so many images to sell itself.
                  • 6. Re: How to reduce PDF export size of Indesign documents?
                    Jeremy AB Community Member
                    I assume you are running on Mac OS X?
                    If so this can be done no problem. The trick is to go through the Print dialog.
                    Go there, then change your page size and scale settings to the reduced size you want.
                    Then click the Printer button at the bottom.
                    In the bottom left click the PDF button with the down arrow, choose Save as Postscript...
                    Give the file a name and save it to your desktop, then run that file through Acrobat Distiller.
                    • 7. Re: How to reduce PDF export size of Indesign documents?
                      Bob Levine CommunityMVP
                      And in the process you'll wind up with a flattened PDF. If you're sending to a client for proofing be prepared to explain that those ugly white lines all over the place won't print like that. And when they print it on their desktop printer and some of the lines do print, you're going to have a real credibility problem on your hands.
                      Just a warning.
                      Bob
                      • 8. Re: How to reduce PDF export size of Indesign documents?
                        Thanks Jeremy.  That worked great.
                        By starting with the print dialoge box it seems to offer more control.
                        I also discovered (after many trials and errors) that it's possible to use Acrobat Professional to trim off any leftover page space from the PDF using the 'crop' command.
                        Very useful!
                        Thanks...
