1 Reply Latest reply on May 8, 2010 1:50 PM by Randy Edmunds
    Edit FTP-files "live"
    wittepoes
      Hi all,
      I've recently switched from CS3 to CS5 and I have some FTP-problems.
      In CS3, I could just work on my FTP-server through Dw, and it would automatically send and retrieve files to/from server.
      In CS5, it does send the files to my server. But when I eg. add a folder via FileZilla, and press F5 in CS5, it doesn't show up...
      How should I configure CS5 in order to get a 'live' view on the ftp-server, like in CS3
      Jan
        • 1. Re: Edit FTP-files "live"
          Randy Edmunds Adobe Employee
          Jan,
          DISCLAIMER: It's dangerous to work this way. I recommend that you only do this on a server that has source control or is regularly backed up so that you can get back to where you started (or something reasonably close) if you make a mistake.
          Set the Remote Server in your Site definition for "Checkout files when opening" and "Automatically upload files to server on Save".
          In the upper-right corner of the Files Panel, there's a drop-down list that defaults to "Local View". If you change that to "Remote Server", then when you double-click on a file, DW automatically downloads a copy to your local folder. On every file save, it uploads your change to the Remote Server.
          Regards,
          Randy
