0 Replies Latest reply on Aug 3, 2007 2:55 PM by thatadbobestephen
    Changing transition effects at runtime
    thatadbobestephen
      I want to allow users to change the effect used on transtions on a
      presentation app I'm building. I have a set of effects defined and
      then use a switch statement to select between each effect. The problem
      is that the switch of effect is only applied once and application
      restart (in a standalone projector) is required to apply a different
      effect.
      What can I do to switch between effects used in a transition without
      an application restart?
      flex sdk 2.01
      Code sample
      case 1:
      chosenEffect.effect = slowZoom;
      break;
      case 2:
      chosenEffect.effect = myMove;
      break;
      myTran.effect = chosenEffect.effect;
      myTranback.effect = chosenEffect.effect;
      // I want flexibility about which state changes the effects apply to ;
      myTran.fromState = "*";
      myTran.toState = "*";
      myTranback.fromState = "state2";
      myTranback.toState = "state1";
      transitions.push(myTran);
      transitions.push(myTranback);
      transition.initialize; // transition is the id of the canvas component
      with many children that I want the effect applied to
