IN photoshop CS5 when you select to print 8 copies of an image only one comes out of the printer...
worked fine with cs3 cs4
any input?
Well, nobody reported these print problems until CS5 had been out a few weeks.
We're looking into it, and have identified some of the underlying problems (older printer drivers not working with the Vista/Win7 printing system).
It may be a while before we (and Microsoft) can come up with a fix.
What printer brand and model? What driver version?
Shinko S1245 their newest drivers!!!
works fine with cs3 which i have on t he same computer basically what ever number copies i enter to cs5 i dont get out of the printer!!!
Also, what OS version?
I don't think we have a Shinko printer in-house, so it may take a while to contact them and work out why the driver is not obeying the Windows number of copies information.
windows 7 32bit
its really weird it prints one and then if u bring up another image it prints the balance amount from the previous printed image>> so like if i ask for 8 it prints 1 and the new image it would print 7 when asked to print just 1
I'm having the same exact problems. Using Windows XP SP3, printing to canon and epson printers.
sorry to say but thank god someone else knows what I'm talking about!!
I wouldnt think it has to do with windows because on the computer i still have cs3 and cs4 and they both work fine
what do we do??
any info from adobe?
Hi, I am having the same problem printing to both my Epson printers. Only started happening after I installed CS5. Have spoken to Adobe and they said they had received a few calls about this. It is now happening intermittently. Sometimes it prints the desired amount but sometimes just reverts itself to 1 print. Most frustrating. Only way to override is to select number of print copies in Epson dialogue box.
same problem here. Doesn't matter what printer I'm printing to or whether it's networked or not.
Quite frustrating.
I print hundreds of photos a day on dye sub printers as of now cs5 is useless until they fix it.....shame on adobe for not testing their software
Epson and Canon users who are seeing this problem, can you please post your specific OS, printers, and printer driver versions?
Have you tried testing multiple copies with a very small image (1x1" @ 72dpi)? If not, can you try this and report back?
With all due respect, and I certainly could be wrong, but how can this be a specific printer issue if people from all different industries with all different kinds of printers have the same problem? I have a small Brother printer, a professional grade Ricoh printer and an HP Designjet plotter all experiencing the same problem...
I have Epson 3800 and 1800. OS Windows Vista 32 bit. I have spoken to Epson and have got the latest drivers. Can't be the printers, only started happening after installing CS5. As I said, problem now intermittent so don,t know whether its going to print the correct number of copies or not.
i am using xp sp3 and xerox printers and having the same issue...
I am using both CS4 and CS5 (both 32bit as the 64 bit will not work on my 64 bit Win 7 machine yet...see other forum win 7 topics). The Epson 4800 takes very long to print with the newer CS5 PS for all menu items (e.g. clicking on print, choosing a different paper, choosing a different ICC/ICM....the initial dialogue print box may take 90 seconds to first appear. when I hit print, it also takes about another 90 seconds before the print head begins getting in the proper postion. My older CS4 PS (32bit) takes about 10 seconds to appear and initiate any dialogue box change. I have a newer i7 intel with 8gig ram...any ideas??? thanks AJZ
I THINK THERE IS A MAJOR PRINTER PROBLEM ALL AROUND THE NEW PHOTOSHOP CS5!!!
I HAVE TO ASSUME WITH ALL THE PEOPLE WRITING IN THEY ARE WORKING ON A UPDATE...
I HAVE STOPPPED USING THE PROBLEM BECAUSE IT SLOWS DOWN MY WHOLE PRINTING PROCESS
I am also seeing this problem on an Epson R1900 in XP SP3
I believe printing in Windows from PS keeps getting worse with each release.
Initial state of print dialog before printing. Print Resolution is 643PPI (4x6 print)
After pressing PRINT only one copy is printed. Selecting File/Print again brings up the following.
Note the preview has reverted to 8.5x11 aspect ratio, and the print resolution is 361PPI. That's the first problem -- the page setup has gone back to defaults. However, press the Print Settings button and you see:
The dialog has the title "Print" and the text is "because the requested printer does not exist".
I dismissed the dialog and pressed PRINT -- it tried to print the image at 8.5.11 size.
The only way to get past this point and be able to re-select the printer settings is to close and reopen the image.
In case it's important, this is a Canon RAW file (.CR2) from a Canon 5D Mark II, opened via ACR 6.1.
Thank you!!!
tina
After a little more experimentation I've found an even quicker way to get stuck:
This will display the truncated error dialog and you are unable to change print settings until you cancel out, close and reopen the image.
Is adobe any closer to fixing this problem the program is almost one month old and is completely unusable for someone running a lab printing multiple photos of one image!!!!
chris thanks for the reply , I have to tell you i have been on windows 7 from day one and cs3 and cs4 have worked fine in the printing area..prior to that i had vista for two years and they to worked fine printing... the easiest work around the problem right now is to use the function print one copy command and hit it for the amount of photos you want, just and fyi....
CS3 and CS4 used the older NT/XP printing system.
CS5 uses the newer Vista/Win7 printing system, and seems to be shaking out a few bugs.
