6 Replies Latest reply on May 10, 2010 8:00 AM by toft
    Getting rid of a video
    toft Level 1
      I have an app that loads and unloads comps into a vgroup. In one of these comps I have a VideoDisplay. When loading another comp I naturally need my video comp to shut up and go away. I have tried stopping the video from anywhere I can think of, inside and outside the comp itself. No luck at all, it happily plays on. (On each new comp loading the vgroup is emptied before loading a new one)
      I have no problem accessing the video comp from the main app. But calling stop() on it does nothing.
      NB! In this case its not an alternative to have a button so the video can be stopped manually. I want it to automaticly stop when loading new stuff.
      What to do ??
        • 1. Re: Getting rid of a video
          David_F57 Level 5
          hi
          If you load the comp and it has a videoplayer in it then you should have no issues sending commands to it from the main app.
          David
          myApp
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:ns1="*">
          <fx:Script>
          <![CDATA[
          protected function button1_clickHandler(event:MouseEvent):void
          myvp.vp.stop();
          myvp.vp.source=null;
          protected function button2_clickHandler(event:MouseEvent):void
          myvp.vp.source="03.flv";
          myvp.vp.play();
          </fx:Script>
          <ns1:myVideoPlayer id="myvp" x="711" y="212"/>
          <s:Button x="913" y="128" label="Unload" click="button1_clickHandler(event)"/>
          <s:Button x="787" y="128" label="Load" click="button2_clickHandler(event)"/>
          </s:Application>
          myComponent
          <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300">
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:VideoPlayer id="vp" x="26" y="19" width="344" height="255"/>
          </s:Group>
          • 2. Re: Getting rid of a video
            toft Level 1
            Thanks David
            I have no problem accessing (tracing shows it) the component containing the video display from the main app. It simply doesnt respond to stop();, source = null;
            Note: In your sample you include the component in mxml. I add the components dynamicly using as. Can that make difference when loading / unloading components ?
            • 3. Re: Getting rid of a video
              David_F57 Level 5
              hi,
              I tried it loading an as component dynamically and still it worked, can you give me an idea of how you are instantiating the component...
              application
                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:ns1="*" creationComplete="application1_creationCompleteHandler(event)">
              <fx:Script>
              <![CDATA[
              import mx.events.FlexEvent;
              private var mp:myPlayer;
              mp.vp.source="03.flv";
              mp.vp.play();
                 mp.vp.stop();
                 mp.vp.source=null;
              protected function application1_creationCompleteHandler(event:FlexEvent):void
              mp = new myPlayer();
              mp.width=600;
              mp.height=400;
              mp.x=5;
              mp.y=40;
              this.addElement(mp);
              </fx:Script>
              <s:Button x="5" y="5" label="load" click="button1_clickHandler(event)"/>
              <s:Button x="75" y="5" label="unload" click="button2_clickHandler(event)"/>
              </s:Application>
              component
              package
              import spark.components.Group;
              import spark.components.VideoPlayer;
              public class myPlayer extends Group
              public var vp:VideoPlayer = new VideoPlayer();
              public function myPlayer()
              super();
              width=400;
              height=300;
              vp.width = this.width;
              vp.height = this.height;
              addElement(vp);
              • 4. Re: Getting rid of a video
                toft Level 1
                Hi David, thanks again...
                Switch in main app:
                case 'ReflectionVideo':
                                        reflectionVideo =  new ReflectionVideo();
                                        initPage(new ReflectionVideoInfo(), new ReflectionVideo(), 20);
                                        break;
                Loading it works fine. And for testing I added a stop-button (as in your last sample) and it stopped the video. The problem is that I dont want a button to stop it, I want it to stop when unloading the videocontainer and  loading new content into the 'host' in the main app. Loading and unloading the various other content works just fine, I just cant that &£# video to shut up !!
                As I`ve mentioned earlier, accessing the reflectionVideo component and it`s video from the main app works fine when trace testing. It just refuse to respond to a stop call.
                • 5. Re: Getting rid of a video
                  David_F57 Level 5
                  hi,
                  The only thing I can think of is that you have 2 instances of the component running but one is not visible, i tried something interesting, I modified my original sample a bit, it loads the player on creation, I have a load source and play  button and a remove player button. After I remove the player then click the  'load' button the video plays again but you only hear it as its not in the display list.
                  http://gumbo.flashhub.net/video/ src included
                  press the load(play) then unload then load again....
                  David.
                  • 6. Re: Getting rid of a video
                    toft Level 1
                    Good news and bad news.
                    Good news: I tried using the spark VideoDisplay instead of the mx one and it works !! (Why the #€@ didnt I think of that earler ??)
                    Bad news: Have probably wasted lots of your time...
                    Well, thanks as always David, really appreciate your kind assistance when in flex despair...
