1. Re: Adding the Trademark symbol to a document
Mike Wickham May 9, 2010 3:51 PM (in response to judsha)You don't need to put the trademark symbol on a reference page. Just type
^q* wherever you want to insert it in your text.
2. Re: Adding the Trademark symbol to a document
Mike Wickham May 9, 2010 4:05 PM (in response to judsha)You know, I didn't even know there was a Character Macros feature on a
reference page, so I looked it up. It appears that it is there only for
converting characters to an HTML equivalent. So the macros set up there make
the conversions only when the file is saved as HTML. For example, if you use
^q* to insert a trademark symbol in your document, when you save to HTML,
the trademark character will convert to whatever you set, such as "(tm)."
3. Re: Adding the Trademark symbol to a document
judsha May 9, 2010 11:11 PM (in response to Mike Wickham)Thanks for your answer. I guess I need a little more direction. When I
type ^q*, do I have to choose a character format type
? When I type the characters in my "Boby
" fomat, I see exactly what I type. How do I get the TM symbol?
4. Re: Adding the Trademark symbol to a document
Arnis Gubins May 10, 2010 8:19 AM (in response to judsha)^q* = ctrl key.then "q", then shift key, then "8"
5. Re: Adding the Trademark symbol to a document
Mike Wickham May 10, 2010 9:06 AM (in response to judsha)It sounds like you are typing the characters as I wrote them (^q*), but ^q
is FrameMaker's shorthand for controlq. Ctrlq * is the sequence. So you
should press and hold the control key, then press the q key simultaneously.
Then release both. Then hit the asterisk key. FrameMaker will automatically
insert the TM symbol for you, assuming your paragraph format uses a font
that contains the TM character.
6. Re: Adding the Trademark symbol to a document
Sheila Carlisle May 10, 2010 10:18 AM (in response to judsha)If you're using FM 9, the TM symbol should be available from the Character Palette, File > Utilities > Character Palette.
7. Re: Adding the Trademark symbol to a document
mandrill22 May 10, 2010 5:44 PM (in response to judsha) -
8. Re: Adding the Trademark symbol to a document
judsha May 10, 2010 10:59 PM (in response to Mike Wickham)Well, I think I am almost there. But, what font contains
the TM symbol? I gather once I know this, I can create a paragraph or character format with this font and then use it while inserting the characters you listed, right?
9. Re: Adding the Trademark symbol to a document
Reviewer1066 May 11, 2010 5:38 AM (in response to judsha)To my knowledge, virtually all text fonts (not symbol and wingding type fonts) have the trademark symbol. So inserting it from the Symbols dropdown should insert it from the font current at that point.
Van
10. Re: Adding the Trademark symbol to a document
Mike Wickham May 11, 2010 8:16 AM (in response to judsha)Almost all fonts contain the TM symbol. The fonts that may not have it are
fonts not normally used for body text, such as Symbol and Dingbats. Another
easy way to enter the TM symbol (on Windows) is to type Alt-0153. (You must
use the numbers on the number keypad, not the numbers above the qwertyuiop
keys.)
11. Re: Adding the Trademark symbol to a document
judsha May 11, 2010 10:32 PM (in response to Mike Wickham)Well, I finally was able to do it. Thanks for
all your tips especially the ALT + 01
53. That was the one that worked.
12. Re: Adding the Trademark symbol to a document
rstern8 Oct 24, 2014 9:01 AM (in response to judsha)<sup>TM </sup>
13. Re: Adding the Trademark symbol to a document
Syed Zaeem Hosain Oct 24, 2014 10:26 AM (in response to rstern8)Seriously? I hope you don't do it that way! A super-scripted two characters "TM" is not the same as the Trademark character that is what a good document should contain.
Z
14. Re: Adding the Trademark symbol to a document
Error7103 Oct 25, 2014 6:22 AM (in response to Syed Zaeem Hosain)> A super-scripted two characters "TM" is not the same as the Trademark character ...
It's also going to break hypertext links if the string it's in is used for any list generation (TOC, IX, etc.).
In FM8 and later, use the Unicode character U+2122, entered as \u2122 in dialogs (such as to create a variable to represent it). It's a single character code point, inherently superscripted. I presume that on Windows ALT+0153 is mapped to it, as is the legacy Framemaker dialog notation \TM
If ™ doesn't appear, then either the font is a legacy codepage implementation, or if a Unicode font, the font failed to populate a glyph for codepoint 2122.
15. Re: Adding the Trademark symbol to a document
Error7103 Oct 29, 2014 7:19 AM (in response to Error7103)Poking around a bit more on it, there's some peculiar stuff going on with ™, and probably with €‚ƒ„†‡ˆ‰Š‹ŒŽ‘’“”•–—˜š›œŸ as well. These are what might be called the C1 Controls orphans. They are present in Microsoft Code Page 1252 fonts, in the 80h to 9Fh range, but were dropped for ISO 8859-1, as they occupy space reserved for control codes. Unicode adopted 8859-1, and not cp1252, so also kicking these orphans out of that space, known as the C1 Controls.
TM is code point Alt+153 (99h) in cp1252.
Code point U+0099 in Unicode is now an unspecified control character, rendered (if at all) as "XXX" in a dashed box.If we look at a legacy cp1252 font, such as Type 1 Courier, in the Windows Character Map ap, we see TM at code point 153d, aka 99h.
If we look at Type 1 Courier in the FM9 or later Character Palette, code point range 0080h-009F is surprisingly shown as vacant, and TM is surprisingly found at 2122h (which is, of course, impossible, because T1 Courier is an 8-bit font that has has no code points defined above 00FFh). The other C1 orphans are similarly moved to their coordinates in Unicode space (all above FFh).
Is FM synthesizing a Unicode version of Courier, with the C1 Control orphans moved to new code points?
Hard to say.No matter how I enter a TM in FM9 (keyboard shortcut, \TM, ALT+153, \u2122), FM changes the representation to ™. I haven't so far been able to figure out exactly what FM is rendering to PDF for legacy and Unicode TMs. Even if I could find a generic decode-random-text app, Distiller, Acrobat Reader, and the OS clipboard could all be messing with the text code points before pasting it into the app.
This sort of magic goes on everywhere, it seems. Pasting raw TMs (or other special characters) into this forum's dialog routinely results in them being converted to HTML Entity markup, ™ in the case of TM. So, dear readers, be thankful that you only have to write text that includes special characters, and you don't have to write code that processes them from random source encodings to arbitrary receiving/rendering aps and displays.
16. Re: Adding the Trademark symbol to a document
Error7103 Nov 3, 2014 6:19 AM (in response to Error7103)> Is FM synthesizing a Unicode version of Courier, with the C1 Control orphans moved to new code points?
To answer my own question, it sure seems like it. For T1 Courier, FM's Character Palette (CP) shows a considerable number of glyphs above U+00FF. Due to annoying behavior by both FM CP and the Windows Character Map, there's no quick way to build a comprehensive list.
But it's clear that only some of the glyphs above FFh are relocated C1 Control orphans. Many appear to be composed Unicode characters made up of glyphs from various legacy Courier characters.
For example, code point
U+0133 LATIN SMALL LIGATURE IJ
is shown. T1 Courier has no ligature IJ, so this had to be done by compositing I and J.
Another is
U+01E6 LATIN CAPITAL LETTER G WITH CARONThis one is more of a puzzle, because T1 Courier has no stand-alone caron. Perhaps an inverted circumflex, or a lower case v, is being used as a hack.
If an application has nominal Unicode support, performing arbitrary compositing is relatively straight-forward. Unicode does not provide every possible "accented" characters for all scripts. It relies on Combining Diacritics (what in older localization schemes were non-advancing diacriticals, but are more like retreating diacriticals in Unicode). Any app pretending to support Unicode has to know how to merge (scale, place and align) multiple glyph fragments into what appears as a single character.
