2 Replies Latest reply on May 9, 2010 5:35 PM by izycrzy
    Column alignment is off
    Szaint
      My page has a right column and a left column. Both have a 10 px top margin in the CSS but the right column sits lower for some reason. The right column is in a "column container" because there is a another div element below it which is named "bottomright_column". Any ideas why the alignment is off? I'm including the link and the CSS. Thanks.
      http://www.jgraveslawyers.com/
      body {
      font-family: Arial, Helvetica, sans-serif;
      font-size: 1em;
      color: #000;
      /* CSS Document */
      #container {
      width: 960px;
      background: #FFFFFF;
      margin: 0 auto;
      padding-top: 10px;
      padding-left: 10px;
      padding-right: 10px;
      overflow: hidden;
      #banner {
      height: 145px;
      width: 940px;
      background-image: url(images/banner_bg.jpg);
      padding-top: 35px;
      padding-left: 20px;
      #navbar {
      height: 35px;
      width: 960px;
      background-image: url(images/navbar_longbg.jpg);
      #main_image {
      height: 320px;
      width: 960px;
      #left_column {
      float: left;
      width: 540px;
      margin-top: 10px;
      margin-right: 10px;
      padding-right: 30px;
      padding-left: 30px;
      background-color: #EDEDED;
      #column_container {
      float: left;
      width: 350px;
      margin-top: 10px;
      #topright_column {
      width: 300px;
      padding-right: 25px;
      padding-left: 25px;
      background-image: url(images/colpractice02.gif);
      background-repeat: no-repeat;
      #bottomright_column {
      width: 300px;
      padding-left: 25px;
      background-image: url(images/colcontact02.gif);
      #footer {
      width: 960px;
      margin: 0 auto;
      padding-left: 10px;
      overflow: hidden;
        • 1. Re: Column alignment is off
          izycrzy
          Without spending a bunch of time troubleshooting your issue I have a couple of quick suggestions.
          - In DW you could hold down the Command and Option key, (Alt and Control) (I think) on a PC and then click the tag that is causing you the problem. DW will fly out a menu that tells you every single css element that is being used to style that tag. That's a quick way to compare and see if there's some rule you wrote which is affecting one div and not the other or something else you forgot about.
          - If you are just starting the project you could switch to the starter css page templates that come with DW. They all have really nice, stable layouts.
          • 2. Re: Column alignment is off
            Szaint Level 1
            Unfortunately, that option-command trick didn't work for me and I need to understand why the alignment is off so that I don't continue making this mistake. Thanks anyway.
