0 Replies Latest reply on May 9, 2010 10:12 PM by w.johnson
    AdvancedDataGrid not sizing to constraints top-left-bottom-right
    w.johnson
      I have a View (SkinnableContainer) that adds various components to the "contentGroup" of its skin. One of these components is an MXML AdvancedDataGrid (ADG) component. The data provider to the ADG is a customized wrapper that implements IList and wraps a matrix (for this example it is 100 rows x 60 columns.) MyADG horizontal and vertical scrollbars are enabled and, when rendered, MyADG adheres to its left, top and bottom constraints (i.e. the vertical size is correct). I expect the right constraint to also produce a margin of 30 but the ADG overflows and is about 1 1/2 screens wide. I've extracted the relevant chunks below and tried many variations on the parameterization. Maybe someone else can see the obvious.
      View
      addElement(component);
      ViewSkin
      <s:Group id="contentGroup" top="5" left="5" bottom="30" right="5" clipAndEnableScrolling="true"/>
      file: MyAdvancedDataGrid
      <mx:AdvancedDataGrid xmlns:fx="http://ns.adobe.com/mxml/2009"
      top="30" left="30" bottom="30" right="30"
      horizontalScrollPolicy="on" verticalScrollPolicy="on"                                                 allowMultipleSelection="true"
      editable="false"
      resizableColumns="false"
      sortableColumns="true"
      lockedColumnCount="1"
      sortExpertMode="true"
      override public function set dataProvider(value:Object):void {
      if (value is MyDataProvider) {
      var dp:MyDataProvider = value as MyDataProvider;
      // create and install the grid column headers
      var gridColumns:Array = new Array(colHeadings.length);
      for (var j:int = 0; j < gridColumns.length; j++) {
      var colName:String = colHeadings[j];
      var gc:AdvancedDataGridColumn = new AdvancedDataGridColumn( colName );
      gc.labelFunction = numberLabelFunction;
      gc.width = 60;
      gc.sortCompareFunction = mySort;
      gridColumns[j] = gc;
      columns = gridColumns;
      super.dataProvider = value;
      else {
