2 Replies Latest reply on May 10, 2010 12:14 AM by David_F57
    Removing ControlBar from Panel
    Raghuvasa Level 1
      Hi All,
                     i have added controlBar dynamically to a Panel through actionscript in my application.
      how can i remove that dynamically added controlBar from the panel.
      i am using  like this
      panelObject.removeAllChildren();
      but its not working properly. its not removing.
      is there any other way to remove controlBar.
      Can any one help me regarding this?
      thanks in advance
      Raghu.
        • 1. Re: Removing ControlBar from Panel
          David_F57 Level 5
          hi,
          how did you add the controlbar ?
          you can hide the controlbar with mypanel.controlBarVisible=false;
          David.
          • 2. Re: Removing ControlBar from Panel
            Raghuvasa Level 1
            Hi David.
                 Thanks for Reply.
                 Here is the code how i am adding controlBar to the panel
                 var controlBar:ControlBar = new ControlBar();
                       controlBar.height = 30;
                panel.addChild(controlBar);
               its working fine while adding.
              But  after some time i need to add one image to panel. while adding image to panel i need to add controlBar to Panel once again.
               so i need to remove the firstly added controlBar and i have to add new ControlBar.
              but its not removing the firstly added controlBar.
              pls help me regarding this.
            Raghu
