1 Reply Latest reply on May 10, 2010 9:14 PM by Trigon_15
    static text issue/bug?
    Trigon_15
      Coding in AS3
      Adobe AIR 2.0
      File layout
      Frame 1
      Frame 1 (on the stage) there is a static textfield with some text in it.
      Actions
      stop();
      gotoAndPlay("3");
      Frame 2
      Frame 2 (on the stage) is blank
      Actions
      function mainDriver()
        var myNumber:int = 5;
        data_txt.text = String(myNumber);
      Frame 3
      Frame 3 (on the stage) is a Dynamic text textfield called data_txt
      Actions
      stop();
      mainDriver();
      The bug
      What should happen is frame 3 shows the number 5, however it shows nothing???
      It ONLY works when you delete the static textfield in frame 1.
      I have been having Lots of BASIC issue with flash CS5 (using AS3 and AIR 2.0) none of which I had with Flash CS4 (Using AS3 AIR 1.5).
      Does anyone else have this issue, I have tested this file on a few computers and all have the same problem.
      I am also finding that when i copy items from other flash files i get strange issues, none of which i had in cs4.
      Starting to think that flash CS5 is too buggy
      I am running window 7 64bit.
      Any ideas?
