3 Replies Latest reply on May 10, 2010 10:28 PM by J D Flex
    Unable to change bin-debug folder
    J D Flex
      After changing the output folder to WebContent\bin-debug I get the following exception. Any idea on how to fix this.
      Caused by: flex.management.ManagementException: The MBean, 'flex.runtime.Spring BlazeDS Integration Samples:type=MessageBroker.AdminConsoleDisplay,MessageBroker=MessageBroker1,id=AdminConso leDisplay', cannot be registered because the previous MBean with the same name could not be unregistered possibly due to some security setting on the application server. This can be avoided by setting manageable property to false in the configuration file.
          at flex.management.BaseControl.register(BaseControl.java:220)
          at flex.management.runtime.AdminConsoleDisplayRegistrar.<init>(AdminConsoleDisplayRegistrar. java:40)
          at flex.management.runtime.messaging.MessageBrokerControl.<init>(MessageBrokerControl.java:8 5)
          at flex.messaging.MessageBroker.<init>(MessageBroker.java:269)
          at flex.messaging.config.MessagingConfiguration.createBroker(MessagingConfiguration.java:105 )
          at org.springframework.flex.core.MessageBrokerFactoryBean.afterPropertiesSet(MessageBrokerFa ctoryBean.java:132)
          at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMe thods(AbstractAutowireCapableBeanFactory.java:1368)
          at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBe an(AbstractAutowireCapableBeanFactory.java:1334)
