7 Replies Latest reply on May 14, 2010 9:55 AM by Flex harUI
    How do I get a key listener to listen?
    Jerry62712 Level 1
      I added a key listener to process "F1" and "F4" keys.  "F1" will bring up a help screen and "F4" will close it.  The problem is you have to click on the help screen for the "F4" key to work.  What I want to happen is from anywhere in the application you can press "F1" and from in there press "F4" to close it.
      I understand that Flex requires you to initially click somewhere in the application after it is opened before the "F1" will work, but I don't see why further clicks are required for the "F4" to work.
      I started with a [addedToStage="addedToStageHandler();"] and wonder if it should be an application item.  It looks like this:
      private function addedToStageHandler():void
          Application.application.addEventListener(KeyboardEvent.KEY_DOWN, my_keyUpHandler);
          stage.addEventListener(KeyboardEvent.KEY_UP, my_keyUpHandler);
      Where I added the "Application" level.  The "my_keyUpHandler" looks like this:
      private function my_keyUpHandler(event:KeyboardEvent):void
          if (event.ctrlKey)
              var keyCode:uint = event.keyCode;
              if (keyCode == 107 || keyCode == 187 || keyCode == 38)
                  fontSize++;
              else if (keyCode == 109 || keyCode == 189 || keyCode == 40)
                  fontSize--;
          if (event.keyCode == Keyboard.F1) {
              helpAccess();
          if (event.keyCode == Keyboard.F4) {
              currentState=null;
      Help!
