1 Reply Latest reply: May 11, 2010 4:58 PM by crsouser RSS
    File Naming for Image Sequence to work properly?
    crsouser Community Member
      I shot about a 226 shot time lapse this weekend and so far having a severe pain getting it to be a time lapse movie in photoshop.
      Shots were 3 minutes apart.
      Originally I tried using the RAW images, then exported them to full size jpeg, then finally exported them to HD video resolution jpegs thinking format might be part of my issue. But it seems to be more of a naming convention problem.
      Originally tried :
      AAA-XXX-<4 digit shot #>-20100508.<ext> & AAA-XXX-<4 digit shot #>-20100509.<ext>  as it spanned over night. Once sequence was loaded I then saved as PSD before trying to export.
      That would only load the very first image, even though it would come up with the frame rate question.
      Then I shorted it to 0508-HHMMSS.jpg & 0509-HHMMSS.jpg and set the frame rate to 10 frames per second. It warned "This sequence has gaps". Once sequence was loaded I then saved as PSD before trying to export.
      This created a 36 minute timeline in CS5 but the opening image was the one I selected, and then about 36 minutes of blank, with a random image from somewhere in the middle of the scene being the last frame.
      I tried this in both CS5 and CS4 thinking it may be a bug just in CS5.. but I get the exact same results.
      What naming convention is the Image Sequencing 'open' really looking for to work properly. I would have thought that either of the above would have worked.. but so far they are not.
      Any help would be appreciated.
      Using Adobe Photoshop CS5 & CS4.
      Christopher
