3 Replies Latest reply on May 11, 2010 1:44 AM by hans-g.
    Unwanted space when working with tables
    MTX212s
      I have created a layout using tables (in CS4), and when I top align the tables containing images and text, it leaves a large, blank, unwanted space at the bottom. I am unable to resize the tables accordingly to eliminate the space, how can I fix this? Here's an image
        • 1. Re: Unwanted space when working with tables
          John Waller Adobe Community Professional & MVP
          Images don't help much since the answer's in the code.
          Can you post a link or the code?
          Any reason you're not using a CSS-driven layout? Much more versatile than table based.
          • 2. Re: Unwanted space when working with tables
            MTX212s Level 1
            Unfortunately, I'm not familiar with coding for CSS. If I was able to layout a site with CSS the way I had envisioned, I totally would have, I just don't know how. Any suggestions? Anyways, here's my code:
            <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
            <html xmlns="http://www.w3.org/1999/xhtml">
            <head>
            <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
            <title>The Crisis // Crew</title>
            <style type="text/css">
            body, td, th {
            color: #000;
            body {
            background-color: #161616;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            td img {
            display: block;
            }td img {display: block;}
            </style>
            .borderTable {
            margin: auto auto;
            border-collapse: collapse;
            border: 1px solid black;
            .Arial {
            font-family: Arial, Helvetica, sans-serif;
            .Arial {
            font-size: 12px;
            color: #333;
            a:link {
            color: #333;
            a:visited {
            color: #333;
            .center {
            color: #FFF;
            font-size: 14px;
            text-align: center;
            .arial {
            text-align: center;
            color: #FFF;
            .bodytext {
            font-size: 12px;
            text-align: left;
            </style>
            function MM_preloadImages() { //v3.0
              var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
                var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
                if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
            function MM_findObj(n, d) { //v4.01
              var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
                d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
              if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
              for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
              if(!x && d.getElementById) x=d.getElementById(n); return x;
            function MM_nbGroup(event, grpName) { //v6.0
              var i,img,nbArr,args=MM_nbGroup.arguments;
              if (event == "init" && args.length > 2) {
                if ((img = MM_findObj(args[2])) != null && !img.MM_init) {
                  img.MM_init = true; img.MM_up = args[3]; img.MM_dn = img.src;
                  if ((nbArr = document[grpName]) == null) nbArr = document[grpName] = new Array();
                  nbArr[nbArr.length] = img;
                  for (i=4; i < args.length-1; i+=2) if ((img = MM_findObj(args[i])) != null) {
                    if (!img.MM_up) img.MM_up = img.src;
                    img.src = img.MM_dn = args[i+1];
              } else if (event == "over") {
                document.MM_nbOver = nbArr = new Array();
                for (i=1; i < args.length-1; i+=3) if ((img = MM_findObj(args[i])) != null) {
                  img.src = (img.MM_dn && args[i+2]) ? args[i+2] : ((args[i+1])? args[i+1] : img.MM_up);
              } else if (event == "out" ) {
                for (i=0; i < document.MM_nbOver.length; i++) {
                  img = document.MM_nbOver[i]; img.src = (img.MM_dn) ? img.MM_dn : img.MM_up; }
              } else if (event == "down") {
                nbArr = document[grpName];
                if (nbArr)
                  for (i=0; i < nbArr.length; i++) { img=nbArr[i]; img.src = img.MM_up; img.MM_dn = 0; }
                document[grpName] = nbArr = new Array();
                for (i=2; i < args.length-1; i+=2) if ((img = MM_findObj(args[i])) != null) {
                  img.src = img.MM_dn = (args[i+1])? args[i+1] : img.MM_up;
            </script>
            </head>
            <body onload="MM_preloadImages('Photoshop/Animation/Top_r2_c4_f3.jpg','Photoshop/Animation/Top_ r2_c4_f2.jpg','Photoshop/Animation/Top_r2_c4_f4.jpg','Photoshop/Animation/Top_r2_c8_f3.jpg ','Photoshop/Animation/Top_r2_c8_f2.jpg','Photoshop/Animation/Top_r2_c8_f4.jpg','Photoshop /Animation/Top_r2_c10_f3.jpg','Photoshop/Animation/Top_r2_c10_f2.jpg','Photoshop/Animation /Top_r2_c10_f4.jpg','Photoshop/Animation/Top_r3_c2_f3.jpg','Photoshop/Animation/Top_r3_c2_ f2.jpg','Photoshop/Animation/Top_r3_c2_f4.jpg','Photoshop/Animation/Top_r3_c6_f3.jpg','Pho toshop/Animation/Top_r3_c6_f2.jpg','Photoshop/Animation/Top_r3_c6_f4.jpg')">
            <table width="870" border="0" align="center" cellpadding="0" cellspacing="3">
              <tr>
                <td><table border="0" cellpadding="0" cellspacing="0" width="870">
                  <!-- fwtable fwsrc="PageTop2.png" fwpage="Page 1" fwbase="Top.jpg" fwstyle="Dreamweaver" fwdocid = "427913899" fwnested="0" -->
                  <tr>
                    <td><img src="Photoshop/Animation/spacer.gif" width="277" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="66" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="33" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="95" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="28" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="77" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="31" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="107" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="18" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="117" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="21" height="1" border="0" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="1" height="1" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td colspan="11"><img name="Top_r1_c1" src="Photoshop/Animation/Top_r1_c1.jpg" width="870" height="195" border="0" id="Top_r1_c1" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="1" height="195" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td colspan="3"><img name="Top_r2_c1" src="Photoshop/Animation/Top_r2_c1.jpg" width="376" height="1" border="0" id="Top_r2_c1" alt="" /></td>
                    <td rowspan="3"><a href="artists.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r2_c4','Photoshop/Animation/Top_r2_c4_f3.jpg',1 );" onmouseover="MM_nbGroup('over','Top_r2_c4','Photoshop/Animation/Top_r2_c4_f2.jpg','Photos hop/Animation/Top_r2_c4_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r2_c4" src="Photoshop/Animation/Top_r2_c4.jpg" width="95" height="52" border="0" id="Top_r2_c4" alt="" /></a></td>
                    <td colspan="3"><img name="Top_r2_c5" src="Photoshop/Animation/Top_r2_c5.jpg" width="136" height="1" border="0" id="Top_r2_c5" alt="" /></td>
                    <td rowspan="2"><a href="gallery.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r2_c8','Photoshop/Animation/Top_r2_c8_f3.jpg',1 );" onmouseover="MM_nbGroup('over','Top_r2_c8','Photoshop/Animation/Top_r2_c8_f2.jpg','Photos hop/Animation/Top_r2_c8_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r2_c8" src="Photoshop/Animation/Top_r2_c8.jpg" width="107" height="51" border="0" id="Top_r2_c8" alt="" /></a></td>
                    <td rowspan="3"><img name="Top_r2_c9" src="Photoshop/Animation/Top_r2_c9.jpg" width="18" height="52" border="0" id="Top_r2_c9" alt="" /></td>
                    <td rowspan="3"><a href="contact.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r2_c10','Photoshop/Animation/Top_r2_c10_f3.jpg' ,1);" onmouseover="MM_nbGroup('over','Top_r2_c10','Photoshop/Animation/Top_r2_c10_f2.jpg','Phot oshop/Animation/Top_r2_c10_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r2_c10" src="Photoshop/Animation/Top_r2_c10.jpg" width="117" height="52" border="0" id="Top_r2_c10" alt="" /></a></td>
                    <td rowspan="3"><img name="Top_r2_c11" src="Photoshop/Animation/Top_r2_c11.jpg" width="21" height="52" border="0" id="Top_r2_c11" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="2"><img name="Top_r3_c1" src="Photoshop/Animation/Top_r3_c1.jpg" width="277" height="51" border="0" id="Top_r3_c1" alt="" /></td>
                    <td rowspan="2"><a href="index.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r3_c2','Photoshop/Animation/Top_r3_c2_f3.jpg',1 );" onmouseover="MM_nbGroup('over','Top_r3_c2','Photoshop/Animation/Top_r3_c2_f2.jpg','Photos hop/Animation/Top_r3_c2_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r3_c2" src="Photoshop/Animation/Top_r3_c2.jpg" width="66" height="51" border="0" id="Top_r3_c2" alt="" /></a></td>
                    <td rowspan="2"><img name="Top_r3_c3" src="Photoshop/Animation/Top_r3_c3.jpg" width="33" height="51" border="0" id="Top_r3_c3" alt="" /></td>
                    <td rowspan="2"><img name="Top_r3_c5" src="Photoshop/Animation/Top_r3_c5.jpg" width="28" height="51" border="0" id="Top_r3_c5" alt="" /></td>
                    <td rowspan="2"><a href="crew.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r3_c6','Photoshop/Animation/Top_r3_c6_f3.jpg',1 );" onmouseover="MM_nbGroup('over','Top_r3_c6','Photoshop/Animation/Top_r3_c6_f2.jpg','Photos hop/Animation/Top_r3_c6_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r3_c6" src="Photoshop/Animation/Top_r3_c6.jpg" width="77" height="51" border="0" id="Top_r3_c6" alt="" /></a></td>
                    <td rowspan="2"><img name="Top_r3_c7" src="Photoshop/Animation/Top_r3_c7.jpg" width="31" height="51" border="0" id="Top_r3_c7" alt="" /></td>
                    <td><img src="Photoshop/Animation/spacer.gif" width="1" height="50" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td><img name="Top_r4_c8" src="Photoshop/Animation/Top_r4_c8.jpg" width="107" height="1" border="0" id="Top_r4_c8" alt="" /></td>
                  </tr>
                </table></td>
              </tr>
              <tr>
                <td width="870" bgcolor="#161616"><table width="870" border="0" cellspacing="0" cellpadding="0">
                  <tr>
                    <td width="605" bgcolor="#FFFFFF" Valign="top"><table width="870" border="0" cellspacing="10" cellpadding="0">
                      <tr>
                        <td width="572"><table width="553" border="0" cellspacing="0" cellpadding="5">
                          <tr>
                            <td width="300" valign="top"><img src="Crew-Photo" width="300" height="451" /></td>
                            <td width="235" valign="top"><span class="bodytext">Andy Madeleine - Director/ Producer/ Editor <br />
            Adam Rock - Assitant Director<br />
            Jacob Kubon - Director of Photography<br />
            Justin Dixon - Sound <br />
            Vaughn Greathouse - Grip</span></td>
                          </tr>
                        </table>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p>
                          <p> </p></td>
                        <td width="268" valign="top"><table width="268" border="0" align="center" cellpadding="2" cellspacing="0">
                          <tr>
                            <td bgcolor="#666666" class="center">About</td>
                            </tr>
                          </table>
                          <span class="bodytext"><br />
                            The Crisis is more than just a documentary film, it is an alliance of hip-hop artists, fans,  and likeminded individuals who are interested in preserving the integrity of the hip-hop community, and maintaining hip-hop as an art.
                            Commercial music has taken over the mainstream, and in doing so, created a channeled, often negative image of hip-hop. The Crisis will attempt to educate the uninformed, discredit stereotypes, and push for a positive image surrounding hip-hop culture. <br />
                            <br />
                            </span>
                            <tr>
                              <td bgcolor="#666666" class="center">Get Involved!</td>
                              </tr>
                            </table>
                            Interested in getting involved? Become part of the project or help us promote! Artists, film-makers, or fans, send e-mails to: <a href="mailto:crisisfilm@gmail.com">crisisfilm@gmail.com</a><br />
                            <br />
                            </span>
                          <table width="268" border="0" cellspacing="0" cellpadding="2">
                            <tr>
                              <td bgcolor="#666666" class="center">Follow The Crisis</td>
                              </tr>
                            </table>
                          <table width="100" border="0" align="center" cellpadding="5" cellspacing="0">
                            <tr>
                              <td><a href="http://www.facebook.com/pages/The-Crisis-Film/120240911333083" target="_blank"><img src="facebook_button_11.jpg" width="35" height="35" alt="Facebook" /></a></td>
                              <td><img src="twitter-button copy.jpg" width="35" height="35" alt="Twitter" /></td>
                              <td><img src="YoutubeButton.jpg" width="35" height="35" alt="YouTube" /></td>
                              </tr>
                            </table>
                          <p> </p>
                          <p> </p>
                          <p> </p></td>
                      </tr>
                      </table>
                      <img src="Photoshop/Bottom_stamp.jpg" width="870" height="100" /></td>
                    </tr>
                </table></td>
              </tr>
            </table>
            <div align="center"><span class="Arial"><a href="index.html">Home</a> I <a href="artists.html">Artists</a> I <a href="crew.html">Crew</a> I <a href="gallery.html">Gallery</a> I <a href="contact.html">Contact</a><br />
              Copyright © 2010 Andy Madeleine. All Rights Reserved.<br />
            </span></div>
            </body>
            </html>
            • 3. Re: Unwanted space when working with tables
              hans-g. Adobe Community Professional & MVP
              in my solution I replaced all parts of your table with a single 6 columns table. Column 1, 3 and 5 are empty, they each have a width of 2%. This gives you always a little white (naturally you can change it) space between the other columns. The properties for horizontal and vertical I set to middle and top.
              I also distorted your email address a little bit (pishing).
              Hans-G.
              <head>
              body, td, th {
              color: #000;
              body {
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              td img {
              display: block;
              </style>
              .borderTable {
              margin: auto auto;
              .Arial {
              .Arial {
              font-size: 12px;
              color: #333;
              a:link {
              color: #333;
              a:visited {
              color: #333;
              .center {
              color: #FFF;
              font-size: 14px;
              text-align: center;
              .arial {
              text-align: center;
              color: #FFF;
              .bodytext {
              font-size: 12px;
              text-align: left;
              </style>
                  if (nbArr)
              </script>
              </head>
              <body onload="MM_preloadImages('Photoshop/Animation/Top_r2_c4_f3.jpg','Photoshop/Anim ation/Top_r2_c4_f2.jpg','Photoshop/Animation/Top_r2_c4_f4.jpg','Photoshop/Animat ion/Top_r2_c8_f3.jpg','Photoshop/Animation/Top_r2_c8_f2.jpg','Photoshop/Animatio n/Top_r2_c8_f4.jpg','Photoshop/Animation/Top_r2_c10_f3.jpg','Photoshop/Animation /Top_r2_c10_f2.jpg','Photoshop/Animation/Top_r2_c10_f4.jpg','Photoshop/Animation /Top_r3_c2_f3.jpg','Photoshop/Animation/Top_r3_c2_f2.jpg','Photoshop/Animation/T op_r3_c2_f4.jpg','Photoshop/Animation/Top_r3_c6_f3.jpg','Photoshop/Animation/Top _r3_c6_f2.jpg','Photoshop/Animation/Top_r3_c6_f4.jpg')">
                <tr>
                    <tr>
                    </tr>
                    <tr>
                    </tr>
                    <tr>
                      <td rowspan="3"><a href="artists.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r2_c4','Photoshop/Animation/Top_r2_c4 _f3.jpg',1);" onmouseover="MM_nbGroup('over','Top_r2_c4','Photoshop/Animation/Top_r2_c4_f2.jp g','Photoshop/Animation/Top_r2_c4_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r2_c4" src="Photoshop/Animation/Top_r2_c4.jpg" width="95" height="52" border="0" id="Top_r2_c4" alt="" /></a></td>
                      <td rowspan="2"><a href="gallery.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r2_c8','Photoshop/Animation/Top_r2_c8 _f3.jpg',1);" onmouseover="MM_nbGroup('over','Top_r2_c8','Photoshop/Animation/Top_r2_c8_f2.jp g','Photoshop/Animation/Top_r2_c8_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r2_c8" src="Photoshop/Animation/Top_r2_c8.jpg" width="107" height="51" border="0" id="Top_r2_c8" alt="" /></a></td>
                      <td rowspan="3"><a href="contact.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r2_c10','Photoshop/Animation/Top_r2_c 10_f3.jpg',1);" onmouseover="MM_nbGroup('over','Top_r2_c10','Photoshop/Animation/Top_r2_c10_f2. jpg','Photoshop/Animation/Top_r2_c10_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r2_c10" src="Photoshop/Animation/Top_r2_c10.jpg" width="117" height="52" border="0" id="Top_r2_c10" alt="" /></a></td>
                    </tr>
                    <tr>
                      <td rowspan="2"><a href="index.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r3_c2','Photoshop/Animation/Top_r3_c2 _f3.jpg',1);" onmouseover="MM_nbGroup('over','Top_r3_c2','Photoshop/Animation/Top_r3_c2_f2.jp g','Photoshop/Animation/Top_r3_c2_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r3_c2" src="Photoshop/Animation/Top_r3_c2.jpg" width="66" height="51" border="0" id="Top_r3_c2" alt="" /></a></td>
                      <td rowspan="2"><a href="crew.html" target="_top" onclick="MM_nbGroup('down','navbar1','Top_r3_c6','Photoshop/Animation/Top_r3_c6 _f3.jpg',1);" onmouseover="MM_nbGroup('over','Top_r3_c6','Photoshop/Animation/Top_r3_c6_f2.jp g','Photoshop/Animation/Top_r3_c6_f4.jpg',1);" onmouseout="MM_nbGroup('out');"><img name="Top_r3_c6" src="Photoshop/Animation/Top_r3_c6.jpg" width="77" height="51" border="0" id="Top_r3_c6" alt="" /></a></td>
                    </tr>
                    <tr>
                    </tr>
                  </table></td>
                </tr>
                <tr>
                  <td width="870" bgcolor="#161616"><table width="99%" border="0" cellspacing="0" cellpadding="0">
                    <tr>
                      <td width="605" bgcolor="#FFFFFF" Valign="top"><table border="3">
                        <tr>
                          <td width="2%"> </td>
                          <td width="30%"><img src="Crew-Photo" width="300" height="451" /></td>
                          <td width="30%" align="left" valign="top"><span class="bodytext">Andy Madeleine - Director/ Producer/ Editor <br />
              Vaughn Greathouse - Grip<br />
              <br />
                          </span></td>
                          <td width="30%" align="left" valign="top"><table width="268" border="0" align="center" cellpadding="2" cellspacing="0">
                            <tr>
                            </tr>
                          </table>
                              <br />
                            </span>
                              <tr>
                              </tr>
                            </table>
              Interested in getting involved? Become part of the project or help us promote! Artists, film-makers, or fans, send e-mails to: <a href="mailto:XXXXXXXXXX@gmail.com">XXXXXXXXXX@gmail.com</a><br />
              <br />
                            </span>
                              <tr>
                              </tr>
                            </table>
                              <tr>
                              </tr>
                            </table></td>
                        </tr>
                      </table>
                      </tr>
                  </table></td>
                </tr>
              </table>
              </span></div>
              </body>
              </html>
