1 Reply Latest reply on May 10, 2010 4:47 PM by Sean_Wilson
    Passing Var values to Flash from Director
    carl_si Level 1
      I currently have a SWF file that we set vars with using a HTML file.  Here are the vars I sent in html:
      var flashvars = {   path: "1.mov",   caption: "captions.xml",   navigation: "nav.xml" };
      I needed to use the same SWF file in a Director project.  So I imported the SWF file, put it in the time line, and setup a frame script as follows:
      on enterFrame me
      sprite(1).setVariable("path", "1.mov")
      sprite(1).setVariable("caption", "captions.xml")
      sprite(1).setVariable("navigation", "nav.xml")
      go to the frame
      end enterFrame me
      This is not working.  Is the Lingo correct?
      The entire html file is located here: http://dl.dropbox.com/u/3238031/index.html
      Any help would be appreciated.
