10 Replies Latest reply on Aug 28, 2007 5:38 AM by Newsgroup_User
    Dreamweaver CS3 slow running one possible fix
    Dai Bando Level 1
      Hi Guys
      I have seen several threads relating to Dreamweaver CS3 running slow - some about Managing Sites. I was having the same trouble and when clicking on a site it took over 30 seconds to bring the Edit Box up.
      I have been running Windows Defender and there is no settings adjustment in that at all. So I decided to take it off - et voila!
      Sites take exactly 1 second to appear, and MY problem at least appears to be fixed. I just thout I would pass this on in case anyone else is having the same problem. If you are, disable your firewall and test DW without it.
      It is so easy to blame Adobe when other programs are causing the problems.
      Hope this helps others.
      David Roberts
        • 1. Re: Dreamweaver CS3 slow running one possible fix
          Level 7
          Funny - thanks for posting this. But I run Defender on all my PCs and do
          not see such an effect.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Derob99" <webforumsuser@macromedia.com> wrote in message
          news:fanm7l$8qn$1@forums.macromedia.com...
          > Hi Guys
          > some
          > site
          > in
          > be
          > same
          > David Roberts
          • 2. Re: Dreamweaver CS3 slow running one possible fix
            Dai Bando Level 1
            God knows where I got Defender from. I should have said Windows Live One Care - not Defender.
            Also, sometimes it makes a difference on which gets put on first. In my case, CS3 was put on first after a hard drive wipe.
            • 3. Re: Dreamweaver CS3 slow running one possible fix
              Level 7
              Ahh - different kettle of fish, that. I believe One Care has a Firewall and
              real-time AV setup, which would be the culprit, I think.
              news:fantu5$g7v$1@forums.macromedia.com...
              > Care -
              > not Defender.
              > case,
              • 4. Re: Dreamweaver CS3 slow running one possible fix
                Dai Bando Level 1
                Unfortunately, Murray, Live One Care has virutally no user settings at all. It is pretty much install and go with what they give you.
                Anyway, hopefully this will help others in the same boat.
                • 5. Re: Dreamweaver CS3 slow running one possible fix
                  Level 7
                  news:fap71p$s6a$1@forums.macromedia.com...
                  I should have read the full post before taking of Defender. Anyhooo I am not
                  running "Live one Care" and I still have the same problem. I also cannot
                  upload anything to my site using site manager. A pop up says login or
                  password error. I have checked and rechecked and it will not connect. I can
                  however log in to my server directly, but I don't wish to do it this way.
                  Any help would be gratefully appreciated .
                  CH
                  • 6. Re: Dreamweaver CS3 slow running one possible fix
                    Level 7
                    Are you running a local firewall? Have you tried connecting with this
                    turned off?
                    Also, please tell us how you have configured your remote site definition.
                    "CartoonHead" <Andre9@nospam.btinternet.com> wrote in message
                    news:fasak3$bfv$1@forums.macromedia.com...
                    > not running "Live one Care" and I still have the same problem. I also
                    > cannot upload anything to my site using site manager. A pop up says login
                    > or password error. I have checked and rechecked and it will not connect. I
                    > can however log in to my server directly, but I don't wish to do it this
                    > way. Any help would be gratefully appreciated .
                    > CH
                    • 7. Re: Dreamweaver CS3 slow running one possible fix
                      Level 7
                      "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                      news:fasdeu$ea6$1@forums.macromedia.com...
                      > turned off?
                      Hi Murray thanks for getting back to me so quickly. Yes I have done all
                      that. I think however it is a problem with my housing people. I have another
                      account that I use and that seems to connect no probs. Its a bank holiday
                      weekend here so I will have to wait until Tuesday to check this out. I will
                      post the results
                      • 8. Re: Dreamweaver CS3 slow running one possible fix
                        Level 7
                        Thanks. Please do!
                        news:fasehu$fge$1@forums.macromedia.com...
                        >> turned off?
                        > another account that I use and that seems to connect no probs. Its a bank
                        > holiday weekend here so I will have to wait until Tuesday to check this
                        > out. I will post the results
                        > Thanks
                        • 9. Re: Dreamweaver CS3 slow running one possible fix
                          Level 7
                          news:fask3t$l7p$1@forums.macromedia.com...
                          > Thanks. Please do!
                          Hiya, all sorted the problem was at the housing site. They reset my password
                          and all is fine and dandy.
                          CH
                          • 10. Re: Dreamweaver CS3 slow running one possible fix
                            Level 7
                            Excellent!
                            news:fb14s6$oe7$1@forums.macromedia.com...
                            >> Thanks. Please do!
                            > password and all is fine and dandy.
                            > CH
