1 Reply Latest reply on May 31, 2010 4:52 AM by Diane Vigil
    Missing template
    doccorp
      Hello
      I have a very strange problem with my DW CS4 template. I was intending to edit the template for my website and found the code at the topof the page (see below)
      <html><!-- InstanceBegin template="/Templates/DTemp.dwt" codeOutsideHTMLIsLocked="false" -->
      <head><!-- InstanceBeginEditable name="head" -->
      Problem is the templates folder is empty and the DTemp.dwt file does not exist anywhere on my system.
      I am trying to edit the Footer area which would appear to be in the template. It will let me detach the template so I can then edit the footer but I am concerned it will effect all my other pages ....and not in a good way.
      Can I safely detach the template without my whoel website imploding ?????
      Gab
        • 1. Re: Missing template
          Diane Vigil Level 1
          You can safely detach the DW Template from the page ... but if you ever find the Template and update it, then it will likely wipe out your edits.
          I think it would be safer to either find the Template (best case scenario) or try to recreate it. But I'd do that on a copy of the site, in case anything goes wrong.
