7 Replies Latest reply on May 17, 2010 1:51 AM by celebritymusic
    Problem loading and displaying a swf
    celebritymusic Level 1
      Hi
      I have six buttons, and I want each one to display a corresponding externally loaded swf, 01.swf, 02.swf.
      It works fine, except that sometimes swfs load up, and sometimes they don't.  For example, if I hit button 6, the 06.swf loads.  but if I hit button 6 after hitting 3 other buttons, SOMETIMES 06.swf loads, other times it doens't and I get an error that relates to the removeChild
      var loader2:Loader = new Loader();
      function showVid (evt): void {
      if (e1.data.childAdded2 == true) {this.removeChild(loader2);};
      loader2.load(new URLRequest("videos/"+e1.data.question_num+".swf"));
      loader2.x=-270;
      loader2.y=-155;
      loader2.contentLoaderInfo.addEventListener(Event.COMPLETE, displayVideo);
      function displayVideo (event:Event): void {
      addChild(loader2);
      e1.data.childAdded2 = true;
        • 1. Re: Problem loading and displaying a swf
          1.  your add/remove does nothing useful
          2.  never nest named functions
          3.  use:
          addChild(loader2);
          loader2.x=-270;
          loader2.y=-155;
          function displayVideo (event:Event): void {}
          • 2. Re: Problem loading and displaying a swf
            Thanks kglad
            My apologies for not finishing off my first post - I wasn't concentrating when I hit submit.
            I'm still having a problem getting the videos to show after hitting the buttons a few times.
            For example, if I hit button 1 a number of times in a row, 01.swf loads and plays the first four or five times, but then it won't display.  Sometimes it's less than this many button hits.  And likewise if I hit different buttons randomly.
            I've trimmed the code down some more:
            addChild(loader2);
            loader2.x=-270;
            loader2.y=-155;
            Any idea why?  It feels like a Flash bug.
            Cheers kglad.
            • 3. Re: Problem loading and displaying a swf
              use the trace() function to see what you're doing:
              addChild(loader2);
                trace("videos/"+e1.data.question_num+".swf")
              loader2.x=-270;
              loader2.y=-155;
              • 4. Re: Problem loading and displaying a swf
                That returns videos/01.swf (number of swf depends on button hit).
                If I hit button 1 over and over, it keeps returning...
                videos/01.swf
                videos/01.swf
                videos/01.swf
                videos/01.swf
                videos/01.swf
                but eventually it stops displaying the video after it starts playing it 3 or 4 times.
                I thought it might have been a case of too many instances of video, but the old code was removing the video each time (I tested it too make sure it was), and the problem stilll occured.
                Have you seen anything like this before?  It's a strange one.
                • 5. Re: Problem loading and displaying a swf
                  is flash video (an flv) played in 01.swf?
                  and the trace() returns that value even when the swf no longer loads?  and what do you see that makes you think a swf does not load?
                  • 6. Re: Problem loading and displaying a swf
                    I've converted the videos from avi's to .swfs using Bikisoft Total Video Converter.
                    I might try converting them to flvs.
                    And yes, the trace continues to return the correct string, even when the video doesn't play.
                    • 7. Re: Problem loading and displaying a swf
                      Sorry kglad - I haven't worked on this all week.
                      To answer your question about what makes me think the viodeo isn't loading, is that nothing shows up - the stage background just stays black.  Maybe it is loading, but just not playing?
                      Any ideas?
                      Cheers
                      Shaun
