0 Replies Latest reply on May 11, 2010 12:56 AM by timo-s
    Loading Flash / Flex apps in Adobe AIR
    timo-s Level 1
      Hi there,
      i'm loading a Flex Application in my AIR App and i'm using the `childSandboxBridge` and `parentSandboxBridge` to communicate between those two. Works like a charm.
      But i've tried to load a Flash Application (the main Class extends `Sprite`, not `Application`) and therefore i get a SecurityError when trying to set the `childSandboxBridge` on the loaderInfo object.
      In the Flex app it's like this:
      (I'm casting the loaderInfo since the `childSandboxBridge` Property is only available in AIR.)
          loaderInfo = FlexGlobals.topLevelApplication.systemManager.loaderInfo;
          try {
             Object(loaderInfo).childSandboxBridge = this;
          } catch(e:Error) {
      In my Flash app it's like this:
          loaderInfo = myMainObject.loaderInfo; // myMainObject is the same class as 'root'
          try {
          } catch(e:Error) {
      In the bottom example i get the following SecurityError:
         Error #3206: Caller app:/airapp.swf/[[DYNAMIC]]/1 cannot set LoaderInfo property childSandboxBridge.
      The SecuritySandbox for both examples is 'application'.
      Any ideas why it doesn't work with the Flash app?
      Thanks in advance.
