0 Replies Latest reply on May 11, 2010 3:46 AM by RajDChauhan
    relocating Dreamweaver configuration folder using registry
    RajDChauhan
      I'm trying to relocate the C:\Documents and Settings\<user>\Application Data\Macromedia\Dreamweaver 8 folder on my machine and instruct Dreamweaver to point to the new location via the registry...i'm not having any joy as i can't find where this is done in the registry.
      All i want to do is relocate this folder to the same path on the local D:\ drive.
      For other programs, i search the registry for the desired paths and modify as required. The app then uses data from the new location next time.
      In the case of Macromedia i can only find paths relating to the initial installation which is C:\Program Files\Macromedia\...
      The docs and setting folder contains the current live settings but for the life of me i can't figure out where this path is set/used in dreamweaver.
      Please can someone help?
      The reason i need to relocate is because my profile space is limited (corporate user) but i can relocate config files to other drives which fixes this limitation.
      Thanks for your time.
      Raj
