5 Replies Latest reply: Aug 8, 2007 1:49 AM by RoboColum(n) RSS
    Frameset query
    RoboColum(n) MeganK
      I'm using framesets for the first (and probably last) time I've created a frameset, set-up a topic to display as the initial file in each frame and assigned the frameset file as the default topic in the SSL. All works well until I use the TOC, Index or Search tab to navigate. Then the frameset disappears never to return. I know I'm doing something wrong. I also know I'm going to kick myself so hard when I find out the answer that I'll be ashamed of having asked this question. I just can't seem to grasp how to assign a frame to display a topic in. I've set the frame to "Same Frame" in the advanced SSL options to no effect.
      If it helps I'm trying to get an area of each help topic to behave like a non-scrolling region - for those of you who remember winhelp files - but in the bottom frame and the actual topic displayed in the top frame. The tri-pane view appears as normal. Any hob nailed boot suggestions welcome
