3 Replies Latest reply on May 11, 2010 5:24 AM by Wade_Zimmerman
    Illustrator CS4 Toolbar Icons have 'smeared'!?!
      Hey folks,
      Got a strange problem this morning when starting my work copy of Illustrator CS4, a large number of the toolbar icons have smeared for some reason? See the image below for what I mean, when you click and hold on any one of them all the tools in that family are also smeared, they all appear to work fine mind you.
      Has anyone else had this problem and know of a solution? I have rebooted the system, updated CS4, updated windows, updated graphics driver
      None of the other components of CS4 are having issues.
      I am running CS4 design premium on Windows 7 Ultimate 64bit on a Dell Precision T5500, Xeon E5520 Processor with 12GB of Ram and a Nvidia Quadro FX1800 if that's any help to anyone.
      Thanks in advance.
        • 1. Re: Illustrator CS4 Toolbar Icons have 'smeared'!?!
          Wade_Zimmerman Level 6
          I would think this was conflict of some kind more like a plug in than hardware.
          However if it just started happening it might be something to do with a setting either in the drivers for the card or Illustrator or the system
          you can try toreset your settings by holding down the control, alt and shift keys (all 3 together) while starting Illustrator.
          That will reset the settings or you can move or delete the settings folder if that does not help, sometimes something else in the folder becomes corrupt.
          Also this can be a conflict with a font, if you have installed or updated software recentlyI would suspect that software or font. Have you used any free fonts recently in a document?
          Here is how you find and remove the settings foder
          1. Quit Illustrator.
          2. Rename the AIPrefs file (for example, to AIPrefs.old) in the Users/(user)/AppData/Roaming/Adobe/Adobe Illustrator CS3 Settings folder.
          3. Start Illustrator. Illustrator creates a new preferences file.
          4. you can also just trash this folder if the new preferences work out fine. Also if this does not work then move the entire Adobe Illustrator CS3 Settings folder to a different location like your desktop for temporary storage Illustrator will create a new folder with all the elements required within the folder and those settings will be fresh default.
          However if there is a conflict or hardware issues this will not  probably help.
          if you do not find the in this location do a search for it.
          Also if you have moved the computer or installed any hardware in your desktop it could be the card is no longer seated well or the card is not quite right or the display could be funny or going funny. But I do not think so.
          • 2. Re: Illustrator CS4 Toolbar Icons have 'smeared'!?!
            Strawbridge_UK Level 1
            It was a corrupted AiPrefs file!
            I simply removed the old one from the Users/[user]/appdata/roaming/adobe/illustrator cs4 settings folder and restarted CS4 and it was all sorted.
            Thank you for your help.
