6 Replies Latest reply on May 12, 2010 7:53 AM by Cyman666
    Drag and drop to multiple targets
    Cyman666
      Hi
      Im trying to create a simple drag and drop app where you can drap a movieclip into multiple areas.
      This is the code i have so far (taken from a tutorial i found) thats works perfectly for 1 target but not for multiples. I initially tried giving the targets the same instance name but that didnt work.
      stop();
      var startX:Number;
      var startY:Number;
      square_mc.addEventListener(MouseEvent.MOUSE_DOWN, pickUp);
      square_mc.addEventListener(MouseEvent.MOUSE_UP, dropIt);
      function pickUp(event:MouseEvent):void {
      square_mc.gotoAndStop (2);
      event.target.startDrag(true);
      event.target.parent.addChild(event.target);
      startX = event.target.x;
      startY = event.target.y;
      function dropIt(event:MouseEvent):void {
      event.target.stopDrag();
      var myTargetName:String = "target" + event.target.name;
      var myTarget:DisplayObject = getChildByName(myTargetName);
      if (event.target.dropTarget != null && event.target.dropTarget.parent == myTarget){
        reply_txt.text = "you have 5 days left";
        event.target.removeEventListener(MouseEvent.MOUSE_DOWN, pickUp);
        event.target.removeEventListener(MouseEvent.MOUSE_UP, dropIt);
        event.target.buttonMode = false;
        event.target.x = myTarget.x;
        event.target.y = myTarget.y;
         } else {
        square_mc.gotoAndStop (1);
        event.target.x = startX;
        event.target.y = startY;
      if(counter == 4){
              reply_txt.text = "Congrats, you're finished!";
      square_mc.buttonMode = true;
      does anyone have any ideas?
      Many thanks
      Simon
        • 1. Re: Drag and drop to multiple targets
          you're checking if the drop target's parent is the same as square_mc.  that's not what you probably want.
          what do you want to check when your mc is dropped?
          • 2. Re: Drag and drop to multiple targets
            Cyman666 Level 1
            Well the code above works fine as it is, as in when the mc is dropped over the target it will snap to it, my problem is that i want multiple targets that the one mc will snap to
            • 3. Re: Drag and drop to multiple targets
              are all your targets children of square_mc?
              • 4. Re: Drag and drop to multiple targets
                Cyman666 Level 1
                not sure, how would i tell?
                • 5. Re: Drag and drop to multiple targets
                  zeroskillz Level 3
                  Here you go, I changed a couple things. First, I made the "decision" that all your drop targets would be named 'target'.
                  stop();
                  var startX:Number;
                  var startY:Number;
                       event.target.startDrag()//true);
                          // changed the bit here to set 'myTarget' after the null and name checks are made
                       if (event.target.dropTarget != null && event.target.dropTarget.parent.name == "target")
                            var myTarget = event.target.dropTarget.parent;
                            } else {
                       if(counter == 4)
                  HTH!
                  -Ted
                  • 6. Re: Drag and drop to multiple targets
                    Cyman666 Level 1
                    zeroskillz, that is spot on!!!
                    you are skillfull!
                    Thank you very much
                    Simon
