2 Replies Latest reply on May 11, 2010 7:32 AM by Rothrock
    setValue Problem within a textfield
    DazFaz Level 1
      This works
      _myMov._childMov._TextField.setValue("My Value")
      this does NOT work
      _myMov["_childMov._TextField"].setValue("My Value")
      The problem is that I have an array of strings that will represent paths to embedded text fields:
      This code does NOT work for some reason.
      var myArray:Array = ["_childMov1._TextField","_childMov2._TextField","_childMov3._TextField"]
      for(var i in myArray){
           _myMov[myArray[i]].setValue("My Value")
      Does anyone have any ideas on this one?
      Thanks in advance.
        • 1. Re: setValue Problem within a textfield
          Rothrock Level 5
          That is because there is no object inside of _myMov called "_childMov._TextField". You can't have a period in the middle of a name so I'm certain of that. If you want to do it like this you can do it like so:
          _myMov["_childMov"]["_textField"].setValue("My Value");
          If you need to you could use string functions to break up the variable at the dot.
          • 2. Re: setValue Problem within a textfield
            Rothrock Level 5
            But if they are all the same this would be better:
            var numChildren=3;
            for(var i=0;i<numChildren;i++){
                 var curField:TextField=_myMov["_childMov"+i]._textField
                 curField.setValue();
                 // do what ever else  you want with curField
            Learn to start counting from zero it will help you in the long run.
