11 Replies Latest reply on Feb 9, 2011 4:33 AM by sharduldkhatri
    SecureAMF channel failed for first time initialization
    vu.tuan.anh Level 1
      Hi all,
      I have a Flex application to authenticate with server via RemoteObject.
      It is working normally with http (i.e. amf channel)
      However when I try to login via https, the first access time, Flex application always return Fault error. Subsequent login is OK.
      From server side, I see user has been logged in successfully at first time.
      Is it because the certificate is not trusted? Any idea?
      Thank you,
      Anh
      This is the log that I have from client side:
      LoginCommand Fault: (mx.rpc.events::FaultEvent)#0
        bubbles = false
        cancelable = true
        currentTarget = (null)
        eventPhase = 2
        fault = (mx.rpc::Fault)#1
          content = (Object)#2
          errorID = 0
          faultCode = "Client.Error.MessageSend"
          faultDetail = "Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'https://172.52.22.218:9443/MyApplication/messagebroker/amfsecure'"
          faultString = "Send failed"
          message = "faultCode:Client.Error.MessageSend faultString:'Send failed' faultDetail:'Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: 'https://172.52.22.218:9443/MyApplication/messagebroker/amfsecure''"
          name = "Error"
          rootCause = (mx.messaging.events::ChannelFaultEvent)#3
            bubbles = false
            cancelable = false
            channel = (mx.messaging.channels::SecureAMFChannel)#4
              authenticated = false
              channelSets = (Array)#5
              connected = false
              connectTimeout = -1
              enableSmallMessages = true
              endpoint = "https://172.52.22.218:9443/MyApplication/messagebroker/amfsecure"
              failoverURIs = (Array)#6
              id = (null)
              mpiEnabled = false
              netConnection = (flash.net::NetConnection)#7
                client = (mx.messaging.channels::SecureAMFChannel)#4
                connected = false
                objectEncoding = 3
                proxyType = "none"
                uri = "https://172.52.22.218:9443/MyApplication/messagebroker/amfsecure"
              piggybackingEnabled = false
              polling = false
              pollingEnabled = true
              pollingInterval = 3000
              protocol = "https"
              reconnecting = false
              recordMessageSizes = false
              recordMessageTimes = false
              requestTimeout = -1
              url = "https://172.52.22.218:9443/MyApplication/messagebroker/amfsecure"
              useSmallMessages = false
            channelId = (null)
            connected = false
            currentTarget = (mx.messaging.channels::SecureAMFChannel)#4
            eventPhase = 2
            faultCode = "Channel.Connect.Failed"
            faultDetail = "NetConnection.Call.Failed: HTTP: Failed: url: 'https://172.52.22.218:9443/MyApplication/messagebroker/amfsecure'"
            faultString = "error"
            rejected = false
            rootCause = (Object)#8
              code = "NetConnection.Call.Failed"
              description = "HTTP: Failed"
              details = "https://172.52.22.218:9443/MyApplication/messagebroker/amfsecure"
              level = "error"
            target = (mx.messaging.channels::SecureAMFChannel)#4
            type = "channelFault"
        headers = (null)
        message = (mx.messaging.messages::ErrorMessage)#9
          body = (Object)#2
          clientId = (null)
          correlationId = "F4E42A7F-5E56-B704-CDB6-87826108D443"
          destination = ""
          extendedData = (null)
          headers = (Object)#10
          messageId = "B549C02F-9EDF-7C6E-C89F-878261572A73"
          timestamp = 0
          timeToLive = 0
        statusCode = 0
        target = (null)
        token = (mx.rpc::AsyncToken)#11
          message = (mx.messaging.messages::RemotingMessage)#12
            body = (Array)#13
              [0] (com.mydomain.model.dto::LoginDTO)#14
                statuscode = "0"
                userName = "myusername"
            clientId = (null)
            destination = ""
            headers = (Object)#15
            messageId = "F4E42A7F-5E56-B704-CDB6-87826108D443"
            operation = "authenticate"
            source = (null)
            timestamp = 0
            timeToLive = 0
          responders = (Array)#16
            [0] (com.mydomain.controller::LoginCommand)#17
          result = (null)
        type = "fault"
        • 1. Re: SecureAMF channel failed for first time initialization
          Alex Glosband Adobe Employee
          Hi. Are you using Internet Explorer? If so, have you set add-no-cache-headers to false on the endpoint?
          With Internet Explorer you need to set the add-no-cache-headers property to false in the configuration settings for your endpoint in the services-config.xml file.
          <add-no-cache-headers>false</add-no-cache-headers>
          If that's not the issue please let me know which browser (and what version of the browser) you are testing with and which version of LiveCycle Data Services you are using and I will look into it further. Thanks.
          -Alex
          • 2. Re: SecureAMF channel failed for first time initialization
            vu.tuan.anh Level 1
            Hi Alex,
            Thank you for your reply. It is true that I failed in IE 6, 7, 8 with amf-secure channel. Firefox and Google Chrome is working.
            I have checked the services-config.xml (should be the default) and see the  <add-no-cache-headers>false</add-no-cache-headers> in channel definition my-secure-amf:
            <!-- Secure Servlet-based endpoints -->
                    <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
                        <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                        <properties>
                            <!--HTTPS requests on some browsers do not work when pragma "no-cache" are set-->
                        </properties>
                    </channel-definition>
            For my-amf, it is set to true
            <!-- Servlet Based endpoints -->
                    <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                        <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
                        <properties>
                            <polling-enabled>false</polling-enabled>
                            <add-no-cache-headers>true</add-no-cache-headers>
                            <invalidate-session-on-disconnect>true</invalidate-session-on-disconnect>
                        </properties>
            Is there any other place I need to add the add-no-cache-headers?
            I'm using Websphere application, do I need to set any properties in Websphere?
            Thank you and look forward to your reply,
            Anh
            • 3. Re: SecureAMF channel failed for first time initialization
              vu.tuan.anh Level 1
              By the way, I'm using LCDS 2.6
              does the error relate to attribute CookiesConfigureNoCache in Websphere HTTP Channel?
              Regards,
              Anh
              • 4. Re: SecureAMF channel failed for first time initialization
                vu.tuan.anh Level 1
                My current workaround solution is to invoke a remote object when the application is loaded. After this invocation, the connection is setup properly.
                Thank you and regards,
                Anh
                • 5. Re: SecureAMF channel failed for first time initialization
                  wce2 Level 1
                  Alex,
                  I agree with your statement about setting the "add-no-cache-headers: property to false, but my question is why do we need to do that.  Microsoft's IE website states that the only reason we should need to do this is if IE is attempting to read a file on a remote server, like downloading a spreadsheet.  What is Flex/ActionScript putting on the server that IE thinks it needs to read so that it can receive the response from BlazeDS?
                  WCE 2
                  • 6. Re: SecureAMF channel failed for first time initialization
                    Sébastien VARLET Level 1
                    I am currently facing the same problem: trying to use SecureAMFChannel only but connection fails.
                    I didn't try the workaround yet. Is there any real solution to this problem ? did we misunderstand the way to use/configure blazeds ?
                    Here is the default section of services-config.xml about channels:
                         <properties>
                         </properties>
                    You will notice that <add-no-cache-headers> is already set to false.
                    Tests failed on Chrome 6. Everything is ok if I use basic AMF.
                    • 7. Re: SecureAMF channel failed for first time initialization
                      sharduldkhatri
                      I am still having an issue with IE even though I have added
                      Can you please let me know How to resolve this issue?
                      Shardul
                      • 8. Re: SecureAMF channel failed for first time initialization
                        In my case, the problem was an IT infrastructure design one.
                        Therefore I don't think I can help you !
                        Good luck !
                        Envoyé de mon mobile
                        Le 8 févr. 2011 à 22:52, sharduldkhatri <forums@adobe.com> a écrit :
                        Shardul
                        • 9. Re: SecureAMF channel failed for first time initialization
                          sharduldkhatri Level 1
                          Can you elaborate the infrastructure issue?
                          Shardul
                          • 10. Re: SecureAMF channel failed for first time initialization
                            The design of the network blocked the service calls through firewalls
                            and flows balancers.
                            Shardul
                            • 11. Re: SecureAMF channel failed for first time initialization
                              We have the same design. What solution did you apply.
                              Shardul
