0 Replies Latest reply: May 11, 2010 7:02 AM by Darrell Loverin RSS
    [svn:fx-trunk] 16030: Complete reomove-unsused-rsls and force-rsls compiler options.
    Darrell Loverin Adobe Employee
      Revision: 16030
      Revision: 16030
      Author:   dloverin@adobe.com
      Date:     2010-05-11 07:02:45 -0700 (Tue, 11 May 2010)
      Log Message:
      Add support for new configuration options to the Compiler API and FlexTasks:
                  remove-unused-rsls ?\226?\128?\147 enables the compiler to remove RSLs that are not used by the application.
                  runtime-shared-library-settings.force-rsls ?\226?\128?\147 override an RSL removal decision made by the compiler by forcing an RSL to be loaded.
      QE notes: None.
      Doc notes: New feature.
      Bugs:
      Reviewer: Paul
      Tests run: checkintests, submitted patch to testing service.
      Is noteworthy for integration: No.
      Modified Paths:
          flex/sdk/trunk/modules/antTasks/src/flex/ant/MxmlcTask.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_en. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderConfiguration.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/ConfigurationConstants. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
      Added Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/RuntimeSharedLibrarySettin gsConfiguration.java
