1. Re: How do you switch between 64 bit and 32 bit?
Mylenium May 11, 2010 9:31 AM (in response to KBStudio)I don't follow. I'm reasonably sure it wants you to switch into 32bit image mode, which is unrelated to which version of PS you use. Just do Image --> Mode and that's it...
Mylenium
2. Re: How do you switch between 64 bit and 32 bit?
KBStudio May 11, 2010 10:16 AM (in response to Mylenium)I am running the 64 bit version of CS5 and when I try to load a sequence of images I am told that I need to switch to the 32 bit version of CS5. How is this done?
3. Re: How do you switch between 64 bit and 32 bit?
Farrellart May 11, 2010 10:54 AM (in response to KBStudio)close PS cs5 64bit and open PS cs5 in the start menu.....or in the Program File (x86)/adobe folder
Try again with the 32 bit version. I don't think you can switch to PS 32 bit within the PS 64 bit version.
4. Re: How do you switch between 64 bit and 32 bit?
KBStudio May 11, 2010 11:25 AM (in response to Farrellart)I am not finding a 32 bit version of Photoshop CS5 in the x86 software folder. There is only a png file. Nothing else. Are there two download versions? One 64 bit only and one 32 bit only?
5. Re: How do you switch between 64 bit and 32 bit?
Farrellart May 11, 2010 11:33 AM (in response to KBStudio)I'm only using the cs5 trial version to date but I remember the installer giving me the option not to install the 32 bit version of PS. Which I did as I don't use 32 bit anymore.
My CS4 32 bit is in that location ( program files x86/adobe ) It should be the same for cs5 - but, can't say for definate.
Do a search for it and if it comes up blank try the installer again....it may have been missed first time round.
6. Re: How do you switch between 64 bit and 32 bit?
Charlie Choc May 11, 2010 11:35 AM (in response to KBStudio)The download includes the 32bit and 64bit versions. Maybe you only installed the 64bit version?
7. Re: How do you switch between 64 bit and 32 bit?
Hudechrome-sd9sPI May 11, 2010 12:24 PM (in response to Charlie Choc)To tell the difference:
In the Splash screen, it says Photoshop v12 32 if it's 32 bit and V12 64 if it's the 64 bit. To get to 32 bit, go to Programs (x86) Adobe> Adobe Photoshop C5 and scroll down to the PS application button, about 3/4 the way down the list. Click on that and when the splash appears, be sure it says v12 32 bit.
8. Re: How do you switch between 64 bit and 32 bit?
dec9 May 11, 2010 12:29 PM (in response to KBStudio)Click on Start. Choose all programs. Both will be listed.
9. Re: How do you switch between 64 bit and 32 bit?
KBStudio May 11, 2010 12:37 PM (in response to dec9)I have searched the and don't have a 32 bit version. During
the download and installation, I might have not chosen to install the 32 bit version.
I think I will try to reinstall and see if in fact there is an option. Based on my experience to date, it looks like one really needs to have both installed in order to have the maximum use of all the functions in CS5.
10. Re: How do you switch between 64 bit and 32 bit?
Hudechrome-sd9sPI May 11, 2010 1:29 PM (in response to dec9)No.
11. Re: How do you switch between 64 bit and 32 bit?
Zeno Bokor May 11, 2010 11:45 PM (in response to KBStudio)But what exactly are you trying to do and what is the error message telling you? it seems to me that Photoshop is talking about Image->Mode->32bits/channel and not the 32bit version of Photoshop.
12. Re: How do you switch between 64 bit and 32 bit?
KBStudio May 12, 2010 5:35 AM (in response to Zeno Bokor)Please read entire thread. I am discussing the fact that CS5 requires the 32 bit version to perform certain functions. Looks like I need to reinstall and allow both versions to be loaded.
13. Re: How do you switch between 64 bit and 32 bit?
Zeno Bokor May 12, 2010 5:42 AM (in response to KBStudio)If you want to load multiple images into a single document as separate layers then simply use File->Scripts->Load Files into Stack which works just fine in the 64bit version of Photoshop. The File->Import->Video Frames to Layers command is for importing videos, not images.
14. Re: How do you switch between 64 bit and 32 bit?
Heirloom Bob May 12, 2010 6:53 AM (in response to KBStudio)Similar concern here. No 64 bit version. I purchased the Photoshop CS5 downloadable upgrade. I have installed the program but only see the 32 bit version. Image / Mode shows 8, 16 and 32 bit versions and no 64 bit.
Start Programs offers only a single version of Photoshop which based on the splash screen is 32 bits. Did I miss something during the install?
Bob
15. Re: How do you switch between 64 bit and 32 bit?
Heirloom Bob May 12, 2010 6:54 AM (in response to Heirloom Bob)Windows XP....is that the reason no 64 bit?
16. Re: How do you switch between 64 bit and 32 bit?
Charlie Choc May 12, 2010 7:05 AM (in response to Heirloom Bob)If it's not the 64bit version of XP, then yes.
17. Re: How do you switch between 64 bit and 32 bit?
Charlie Choc May 12, 2010 7:06 AM (in response to Heirloom Bob)Image mode has nothing to do with the program being 32bit or 64bit.
18. Re: How do you switch between 64 bit and 32 bit?
John Joslin May 12, 2010 7:07 AM (in response to Heirloom Bob)Heirloom Bob wrote:
Yes. Win XP is 32-bit.
These are referring to the operating system and application software and have nothing to do with Image modes!
19. Re: How do you switch between 64 bit and 32 bit?
Heirloom Bob May 12, 2010 8:03 AM (in response to KBStudio)But an upgrade to Windows 7 would allow me to take advantage of the 64 bit version right?
20. Re: How do you switch between 64 bit and 32 bit?
John Joslin May 12, 2010 8:40 AM (in response to Heirloom Bob)Providing you got one of the 64-bit versions of Win7.
http://windows.microsoft.com/en-us/windows7/32-bit-and-64-bit-Windows-frequently-asked-que stions
21. Re: How do you switch between 64 bit and 32 bit?
KBStudio May 12, 2010 10:33 AM (in response to John Joslin)Found the answer. I didn't install both versions of CS5. I went back to the installer and found that in fact I had only installed the 64 bit version. I went ahead and installed the 32 bit CS5. So I now have both. I imagine I can switch between them. Which goes back to my original question. How do you do this? Can you do it from one version to the other from within CS5? Or do you need to quit one before opening the other?
22. Re: How do you switch between 64 bit and 32 bit?
SG...May 12, 2010 10:41 AM (in response to KBStudio)
On Windows, you have to quit one before launching the other.
23. Re: How do you switch between 64 bit and 32 bit?
KBStudio May 12, 2010 10:45 AM (in response to SG...)Finally - Thanks SG
24. Re: How do you switch between 64 bit and 32 bit?
gary0a1 Jun 17, 2011 10:13 AM (in response to KBStudio)Switching is all well and good. However why I have to run 32 for video is quite annoying. Will adobe ever put out an update to fix this?
25. Re: How do you switch between 64 bit and 32 bit?
Noel Carboni Jun 17, 2011 10:24 AM (in response to gary0a1)Specifically, what's not working for you in 64 bit?
If it's failing to import the video, that may be a problem with QuickTime. I do know at least one person on this forum has recently claimed that with a current version of QuickTime Pro they've been able to import dirctly into the 64 bit Photoshop :
http://forums.adobe.com/thread/860937
-Noel
26. Re: How do you switch between 64 bit and 32 bit?
SG...Jun 17, 2011 11:41 AM (in response to Noel Carboni)
Hi Gary,
Yes it is annoying, sorry. The File> Import> Video Frames to Layers... relies on a plug-in that's 32-bit only. There is another way to get video frames into layers using Ps CS5 in 64-bit mode.
First open your video file, File> Open...
Then in the popup menu (upper right) of the Animation panel you can find 'Flatten Frames Into Layers'
Does this answer your concern?
regards,
steve
27. Re: How do you switch between 64 bit and 32 bit?
gary0a1 Jun 17, 2011 11:56 AM (in response to SG...)Ummm... kinda not, Steve. :)
Can't open one that way since I don't have PS as the default to open a vid file. So it just opens the player with no choice to "open with". Setting PS to default would be a royal pain since I don't want to (usually) view vids in PS.
(Windows 7)
28. Re: How do you switch between 64 bit and 32 bit?
SG...Jun 17, 2011 12:01 PM (in response to gary0a1)
You don't need to change any opener associations with my suggestion. Launch Ps, then go to File> Open... choose your .mov file (I'm using the Samples CheeziPuffs.mov on Win 7 64) and click Open.
Is that not working for you?
regards,
steve
29. Re: How do you switch between 64 bit and 32 bit?
gary0a1 Jun 17, 2011 12:07 PM (in response to SG...)Nope. Just automatically opens with my default player (GOM) As I said, don't have a choice to "open with".
Gary
30. Re: How do you switch between 64 bit and 32 bit?
Noel Carboni Jun 17, 2011 12:12 PM (in response to gary0a1)He's talking about going into Photoshop itself, choosing File - Open from the menu, then choosing your file in the Open dialog. Are you saying doing exactly that somehow starts your video player?
-Noel
31. Re: How do you switch between 64 bit and 32 bit?
SG...Jun 17, 2011 12:14 PM (in response to Noel Carboni)
I think he's replaced QT with GOM as the default media player and that might be causing some odd interactions. I'm going to install GOM and see what happens here.
32. Re: How do you switch between 64 bit and 32 bit?
SG...Jun 17, 2011 12:38 PM (in response to SG...)
Hi Gary
Well, with GOM Player installed and set as the default video format opener, I'm still not seeing any problem. If I remove QT 7 from the system then I get an expected warning on Open stating that QT 7.1 or greater is required.
Can you open video files in Ps 32 bit? We have to use a different code path to use the QT 32-bit when running Ps in 64-bit mode.
regards,
steve
33. Re: How do you switch between 64 bit and 32 bit?
gary0a1 Jun 17, 2011 1:38 PM (in response to SG...)No problem in 32bit.
And FWIW, after building machines for more than a dozen years I've found (and also known by other builders and coders) installing QT on any windows machine is tantamount to installing a virus.
Might be fine for mac (yes I have one too). Strange things begin to happen to all kinds of things not even related to video. And uninstalling it doesn't help. Formatting is the only way out. It can't be removed completely. (Even tho it says it's gone) But, that's my experience and I'm stuck with it! :)
34. Re: How do you switch between 64 bit and 32 bit?
Ah, so I'm not the only one who feels that way about Apple software on PC.
You can root out many of the excessive things QuickTime sets up by carefully going through an AutoRuns listing, by the way.
-Noel
35. Re: How do you switch between 64 bit and 32 bit?
Christopher Toon Dec 25, 2011 6:28 PM (in response to SG...)Hi Steve
I too am trying to open an .mov file in Photoshop CS5 64bit on OSX Lion. Your suggestion doesn't work - Photoshop refuses to open my .mov file using the File>Open functionality. I don't have the 32bit version. Help!!
Chris
36. Re: How do you switch between 64 bit and 32 bit?
Chris CoxDec 25, 2011 8:11 PM (in response to Christopher Toon)
CS5 installs both 32 and 64 bit on Macintosh, but this is the Windows forum.
On Mac, get info on the application (NOT the folder), and check the box to open in 32 bit addressing.
