1 Reply Latest reply on May 15, 2010 12:38 AM by Peter Grainge
    How can I remove toc/index/search panes that remain when I link to another project?
    lovejoyp
      When I link from my main html file to project A and then click a link to go back to the main html file the toc/index/search pane remains on the screen. How can I remove it?
      I am working with RH8 and Windows 7. I generate Webhelp.
      I have one main html file that has links to projects A and B. Each project is in a separate folder. The projects are not merged.
      I can link to the generated or published files just fine. However, when I start moving around in the files/projects, the toc/index/search panes remain visible.
      For example, if I click the link on the main html file to go to project A it displays correctly. If I click a link to go back to the main html file the toc/index/search pane stays visible for project A. If Iclick the link to go to project B I get another toc/index/search pane and have 2 panes visible.
      How can I make the panes disappear and not remain on the screen when I move from project to project?
      Thanks for the help.
      Pat
