2 Replies Latest reply on May 11, 2010 9:23 AM by Francesco_C
    Rendering runtime loaded fonts
    Francesco_C
      Hi at all (i apologize fot my english)
      i've a swc called fonts.swc loaded at rutime with RSL.
      I created the swc with Flash CS5 embedding 'Showcard' font with new Font Panel.
      My flex app loads the fonts.swc fine but the font does not rendered...
      protected function init():void
                   var embeddedFonts:Array = Font.enumerateFonts();
                  // ShowCard font is in list!!
                   var showcard:Class = systemManager.getDefinitionByName("fonts.ShowcardEmbedded") as Class;
                   Font.registerFont(showcard);
                  myLabel.setStyle("fontFamily", "ShowcardEmbedded");
                 // Font is not rendered in Label spark component.
      Thanks.
      Francesco_C
        • 1. Re: Rendering runtime loaded fonts
          Flex harUI Adobe Employee
          Make sure the embedAsCFF option is set correctly.  If myLabel is a Flex 4
          Spark Label, embedAsCFF must be set to true, otherwise it must be false.
          • 2. Re: Rendering runtime loaded fonts
            Francesco_C Level 1
            Issue solved.
            // Wrong
            <s:Label text="the lazy dog"
                    id="lab"
                    fontSize="56"
                    fontFamily="ShowcardEmbedded"
                    fontLookup="embeddedCFF"
            // Correct
                           lab.setStyle("fontFamily", "Showcard Gothic");
                    id="lab"
                    fontSize="56"
                    fontFamily="Showcard Gothic" // I see 'font name' in Debug Panel
