2 Replies Latest reply on May 12, 2010 5:08 AM by PeterHedrington
    [CS4/JS/AS] doScript pass variable from JS to AS
    PeterHedrington
      I have this doScript that I wish to pass a variable (theFold) to the AppleScript it is calling:
      #target "InDesign-6.0"
      var theFold = ["Spotlight"]
      var myScriptFolderPath = ("Macintosh HD:Users:user:Desktop:Unlock V3.app:");
      app.doScript(File(myScriptFolderPath),ScriptLanguage.applescriptLanguage, theFold);
      The AppleScript is:
      property theAdd : "Macintosh HD:Users:user:Desktop:"
      on run(fromJava)
      tell application "Finder"
      set nameTwo to (fromJava as text)
      set theName to (theAdd & nameTwo) as alias
      my openSez(theName)
      end tell
      end run
      on openSez(theName)
      set folderContents to (items in folder theName)
      if (count of folderContents) > 0 then
      -- cycle through each item in the folder
      repeat with i from 1 to count of folderContents
      set carryThrough to (item i of folderContents)
      -- if it's another folder, then recurse
      if kind of carryThrough is "folder" then
      set theName to (carryThrough as string)
      my openSez(theName)
      else
      if locked of carryThrough is true then
      set locked of carryThrough to false
      end if
      end if
      end repeat
      end if
      end tell
      end openSez
      Is it possible to pass a variable when you call a script from a path?
      I get the error "Can't make <script> into Unicode text.
      Thanks for any help or comments.
      Peter
