Here is my challenge:
(1) Building WebHelp for a web-based data application in 8.0.2.208 (I also have one member working on 5.0.1)
(2) The web-based data application has 1530 data definitions
(3) The Product Manager would like the ability to perform a search for a data defintion by allowing the user to enter text and then initiating a search specific to the list of data definitions and not including the entire application help (i.e., a search on one topic or a collection of topics)
Not sure if this is possible. I would like to:
(1) Have one primary topic with the name of every data definition in the application (again 1530 of them)
(2) Have an entry field where the user types part of the data definition name and allow them to click a button to initiate the search
(3) Put the user at the first item that matches their search
(4) Each item would be a hyperlink to the actual data definition - OR - have all data definitions on one page (YIKES)
--- OR ---
(1) Have a collection of topics with data defintions
(2) Allow the user to enter search criteria and limit the results to the collection of topics related to the data definitions
Is there an "in topic search control" or a search control that can be limited to one topic or a collection of topics?
I have looked at setting up a form with a form field/text field and command button but I cannot find any substantive documentation on how this works or what I need to get it to work.
Any suggestions? As always, thanks for any input.
Michael F Weart
Take a look at ZoomSearch on my site.
This is a GIANT step in the right direction and looks like a solution to my issue.
Two questins:
(1) I downloaded the projects you had posted and followed the steps to build the sample (single project and single search) but once I compile the help and try to click the zoom search button I get a Cannot Load Page message from my browser (IE 7). I also tried to manually open the Search.HTML file from the hard drive and got the same message.
Any idea what I did wrong?
(2) Does this option preclude me from allowing the full search button on tne WebHelp toolbar?
As always - thanks for the assistance.
Michael F Weart
1] Not sure but I often find if people print the instructions and tick things off as they go, suddenly it all works.
2] I don't see why it would but if using ZoomSearch for one thing, I would set up a page that offers two searches, the specific one you want and a general search. ZoomSearch gives the results in a page in the topic pane so there is more room. Also one search method for one search and another method for something else is messy to my mind.
Two last things:
(1) In the Skins setup, I had to add the "Search.html" in the skin to the "ZoomSearch" button using Links and not Advanced. Having it in Advanced did not open the Search form in my help. When I clicked the ZoomSearch menu bar item, it just flashed and did not open the ZoomSearch search topic.
(2) I got the search processing to work in my project, but at some point it stops working. The search topic displays when I click ZoomSearch and results are shown but when I click the link to go to the page listed in the results, I get the standard "Internet Explorer cannot display the web page".
When I look at the link it has:
file:///C:/Research/SearchProcessing/!SSL!/HPI_Change_Metrics.htm
It should have:
file:///C:/Research/SearchProcessing/!SSL!/WebHelp/HPI_Change_Metrics.htm
All I did was re-compile the WebHelp, re-publish the WebHelp, regenerate the search index and repost the 5 Search related files into my WebHelp folder (in the search_files folder). Any idea why it would not have the "WebHelp" included in the path?
As always, thanks --
Michael F Weart
1] The way I have described creating the button does work. Look in my sample project. Is it not working there?
2] That sounds like you have the relative path wrong. See More About Start Options.
