1. Re: Async tests and Assert throws exceptions
Michael Labriola May 11, 2010 3:19 PM (in response to Icantfindanavailablename)The code you have below doesn't do what you think it does.
When you setup an async test in FlexUnit, it needs to know what code is related to a given test. When you use items like the asyncHandler() methods, it basically calls that code in a way that watches for assertions and can manage to track them when they occur.
In your code, you are setting up a timer and that timer is calling another method which does an assertion. The timer calls that code directly from the top of the call stack... in other words, completely outside of FlexUnit. FlexUnit doesn't know your method is being called and cannot wrap the call in order to catch any information thrown from your assertion.
Can you describe what you want to do and I can advise you on the right syntax? It isn't that assertions work differently in async tests, it is that FlexUnit has no idea that the timeout() method is being called, Flash Player is calling it directly, and hence there is no way for it to watch the assertion.
I am guessing you want something more alogn the lines of this, but I am not sure:
Test(async)]
public function myAsyncTest():void
var t:Timer = new Timer(2000, 1);
var handler:Function = Async.asyncHandler( this, timeout );
t.addEventListener(TimerEvent.TIMER, handler );
t.start();
private function timeout(e:Event, passThroughData:Object ):void
Assert.assertEquals(
"apples", "oranges" );
2. Re: Async tests and Assert throws exceptions
Icantfindanavailablename May 11, 2010 4:57 PM (in response to Icantfindanavailablename)Thanks for your reply. It was helpful, but I'm still not out of the woods. The timer example works nicely, with your adjustments. Of course it was just a simple example of an asynchronous test. I can't figure out how to get the real test reporting assertions correctly.
We have an asynchronous mechanism where we request a service and add a success handler callback and a fault (failure) callback. So for example it might look like:
token.addSuccessHandler( myTestSucceeded );
token.addFaultHandler( myTestFailed );...
private function myTestFailed ( error:Error ):void
Assert.fail( "failed\n" + error.message );
The mechanism I'm using always calls the fault handler with an Error parameter. The Assert.fail line is one example of where I would like to use the standard Assert code and have results reported correctly.
The error object that is passed to the fault handler isn't known until the fault actually happens, so I can't provide it to Async.asyncHandler as the passThroughObject. I can't think of a way to make this work.
Thanks again,
DB
3. Re: Async tests and Assert throws exceptions
Michael Labriola May 29, 2010 11:20 AM (in response to Icantfindanavailablename)There is an Async.asyncResponder method which returns a IResponder.
here is the signature:
public static function asyncResponder( testCase:Object, responder:*, timeout:int, passThroughData:Object = null, timeoutHandler:Function = null ):IResponder {
So, you can do something like this:
var responder:IResponder = Async.asyncResponder( this, new TestResponder( handleIntendedResult, handleUnintendedFault ), 50, someDataAlongforTheRide);
var token:AsyncToken = someCallThatReturnsMyToken();
token.addResponder( responder );
Mike
4. Re: Async tests and Assert throws exceptions
nikos101 Dec 23, 2010 3:46 AM (in response to Michael Labriola)Can I use AsyncResponder instead?
[Test(async)]
public function testAttemptLogin():void
var token: AsyncToken = objectToTest.attemptLogin('sre','wd',);
token.addResponder(new AsyncResponder(onResult, faultHandler));
AsyncResponder
