1 Reply Latest reply on Jun 22, 2010 5:42 PM by howaboutthisisthisok
    Help! -  AIR install success and then install failed - both 1.5.3 and 2 beta
      I'm trying to install AIR on Mac OSX 10.6.3.  The installation appears successful.  The installer reports "installation completed" and "adobe air has been successfully installed".  When I click Finish, another window pops up that says "sorry, an error has occurred."  "An error occured while installing Adobe AIR. Installation may not be allowed by your administrator.  Please contact your administrator".
      I've tried uninstalling, reinstalling, uninstaling, tried the 2.0 beta.  I keep getting this error.
      AIR applications (Tweetdeck and Eye-Fi Center Manager) open the AIR Updater, but then it just hangs at 0%.
      Please help.
      Greg
      5/11/10 9:27:57 PM sudo[5205] Greg : TTY=ttys000 ; PWD=/Library/Frameworks ; USER=root ; COMMAND=/Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer -silent
      5/11/10 9:35:00 PM /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Tmp-/airUFeunX/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[5254] MDS Error: unable to create user DBs in /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Caches-//mds
      5/11/10 9:35:01 PM /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Tmp-/airUFeunX/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[5254] MDS Error: unable to create user DBs in /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Caches-//mds
      5/11/10 9:35:22 PM authexec[5269] executing /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Tmp-/airUFeunX/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer
      5/11/10 9:36:45 PM /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Tmp-/air1iKwNZ/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[5288] MDS Error: unable to create user DBs in /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Caches-//mds
      5/11/10 9:36:46 PM /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Tmp-/air1iKwNZ/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR Application Installer.app/Contents/MacOS/Adobe AIR Application Installer[5288] MDS Error: unable to create user DBs in /var/folders/7Q/7QEOZNZAHjGUoTHS+IAwDU+++TI/-Caches-//mds
      5/11/10 9:38:31 PM Adobe AIR Installer[5351] The function `CGContextSetFontRenderingMode' is obsolete and will be removed in an upcoming update. Unfortunately, this application, or a library it uses, is using this obsolete function, and is thereby contributing to an overall degradation of system performance. Please use `CGContextSetFontRenderingStyle' instead.
      5/11/10 9:38:31 PM [0x0-0x11c11c].fi.eye.center.E430518E652B889A80EC0E8A6E532C09FF36DF62.1[5348] Tue May 11 21:38:31 Greg-DePasses-MacBook-Pro.local Adobe AIR Installer[5351] <Error>: The function `CGContextSetFontRenderingMode' is obsolete and will be removed in an upcoming update. Unfortunately, this application, or a library it uses, is using this obsolete function, and is thereby contributing to an overall degradation of system performance. Please use `CGContextSetFontRenderingStyle' instead.
      5/11/10 9:40:16 PM Adobe AIR Installer[5362] The function `CGContextSetFontRenderingMode' is obsolete and will be removed in an upcoming update. Unfortunately, this application, or a library it uses, is using this obsolete function, and is thereby contributing to an overall degradation of system performance. Please use `CGContextSetFontRenderingStyle' instead.
      5/11/10 9:40:16 PM [0x0-0x11e11e].TweetDeckFast.FFF259DC0CE2657847BBB4AFF0E62062EFC56543.1[5357] Tue May 11 21:40:16 Greg-DePasses-MacBook-Pro.local Adobe AIR Installer[5362] <Error>: The function `CGContextSetFontRenderingMode' is obsolete and will be removed in an upcoming update. Unfortunately, this application, or a library it uses, is using this obsolete function, and is thereby contributing to an overall degradation of system performance. Please use `CGContextSetFontRenderingStyle' instead.
      5/11/10 9:46:44 PM sudo[5402] Greg : 1 incorrect password attempt ; TTY=ttys000 ; PWD=/Library/Frameworks ; USER=root ; COMMAND=/Volumes/Adobe AIR/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer -uninstall
      5/11/10 9:46:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] Performing runtime install
      5/11/10 9:46:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] UI SWF load is complete
      5/11/10 9:46:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] UI initialized
      5/11/10 9:46:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] starting user confirmation
      5/11/10 9:46:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] Version of this installer: 2.0.0.12510
      5/11/10 9:46:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] Installed version: 1.5.3.9130
      5/11/10 9:46:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] Installation type: patchNewer
      5/11/10 9:47:04 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] starting elevated install
      5/11/10 9:47:08 PM authexec[5419] executing /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] performing an elevated runtime install
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] UI SWF load is complete
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: starting install
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] starting install
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Scheduling runtime installation operations
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Scheduling runtime installation operations
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Beginning runtime installation
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Beginning runtime installation
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Beginning install
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Beginning install
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Library/Frameworks/Adobe AIR.framework to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      5/11/10 9:47:08 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Library/Frameworks/Adobe AIR.framework to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      5/11/10 9:47:09 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework
      5/11/10 9:47:09 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /Library/Frameworks/Adobe AIR.framework
      5/11/10 9:47:09 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
      5/11/10 9:47:09 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework to /Library/Frameworks/Adobe AIR.framework
      5/11/10 9:47:13 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Applications/Utilities/Adobe AIR Uninstaller.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      5/11/10 9:47:13 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      5/11/10 9:47:14 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
      5/11/10 9:47:14 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /Applications/Utilities/Adobe AIR Uninstaller.app
      5/11/10 9:47:15 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
      5/11/10 9:47:15 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app to /Applications/Utilities/Adobe AIR Uninstaller.app
      5/11/10 9:47:19 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      5/11/10 9:47:19 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      5/11/10 9:47:19 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
      5/11/10 9:47:19 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
      5/11/10 9:47:19 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /Applications/Utilities/Adobe AIR Uninstaller.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app
      5/11/10 9:47:19 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app to /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app
      5/11/10 9:47:22 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      5/11/10 9:47:22 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /Library/Frameworks/Adobe AIR.framework/Versions/Current/Resources/Adobe AIR Updater.app/Contents/Frameworks
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Applications/Utilities/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /Applications/Utilities/Adobe AIR Application Installer.app
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/Current/Adobe AIR Application Installer.app to /Applications/Utilities/Adobe AIR Application Installer.app
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Registering /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist to /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /Applications/Utilities/Adobe AIR Application Installer.app/Contents/Info.plist
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] chown of /Library/Frameworks/Adobe AIR.framework completed with status 0
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] chown of /Applications/Utilities/Adobe AIR Application Installer.app completed with status 0
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status -1
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: chown of /Applications/Utilities/Adobe AIR Uninstaller.app completed with status -1
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/airappinstaller to /Applications/Adobe/Flash Player/AddIns/airappinstaller/airappinstaller
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/airappinstaller to /Applications/Adobe/Flash Player/AddIns/airappinstaller/airappinstaller
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/digest.s to /Applications/Adobe/Flash Player/AddIns/airappinstaller/digest.s
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Copying /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/digest.s to /Applications/Adobe/Flash Player/AddIns/airappinstaller/digest.s
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Execution complete; beginning commit phase
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Execution complete; beginning commit phase
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp0/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      5/11/10 9:47:25 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp1/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp2/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp3/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp4/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Deleting /private/var/folders/zz/zzzivhrRnAmviuee+++++++++++/TemporaryItems/FlashTmp5/temp
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: Commit complete
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] Commit complete
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: install complete
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] install complete
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5419] begin quitting
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] subinstaller: begin quitting
      5/11/10 9:47:26 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] Elevated install completed
      5/11/10 9:48:03 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] Elevated install failed (2038)
      5/11/10 9:48:03 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] runtime install entering error state: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Error #2038" errorID=2038]
      5/11/10 9:48:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] begin quitting
      5/11/10 9:48:57 PM /Volumes/Adobe AIR 1/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer[5404] error in stateQuitting: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Error #3001" errorID=3001]
      5/11/10 9:49:16 PM /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[5443] UI SWF load is complete
      5/11/10 9:49:16 PM /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[5443] UI initialized
      5/11/10 9:57:33 PM /Library/Frameworks/Adobe AIR.framework/Versions/1.0/Resources/Adobe AIR Updater.app/Contents/MacOS/Adobe AIR Installer[5443] begin quitting
