4 Replies Latest reply on May 12, 2010 5:11 AM by David_F57
    SWF Loader and MovieClip problems
    djh88ukwb Level 1
      Hello all.
      I am using the following code to import a swf file that has a number or frames.  When i hit next or previous it moves either to the next or previous frame.
      The code is as follows
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" applicationComplete="load()">
          <mx:Script>
              <![CDATA[
                  private var flashMovie:MovieClip;
                  private function initMovie():void{
                      flashMovie = loader.content as MovieClip;
                  private function load():void{
                      flashMovie.stop()
          </mx:Script>
          <mx:SWFLoader id="loader" source="flash.swf" complete="initMovie()"/>
          <mx:Button label="Next" click="flashMovie.nextFrame()"/>
          <mx:Button label="Previous" click="flashMovie.prevFrame()"/>
      </mx:Application>
      This works fine, everything is as i want, apart from i want what ever SWF frame is being displayed, to be displayed on all web browsers that have the page open.
      I imagine i would be able to use an XML file, and pull the frame being displayed from that and have it check the XML file every couple of seconds ?
      Although saying that im not 100% sure on how to achieve this.
      Can anyone offer some help please?
        • 1. Re: SWF Loader and MovieClip problems
          djh88ukwb Level 1
          Ok,  So i have been working on this concerpt a little more.
          I have created a HTTPS service,
              <mx:HTTPService id="getImage" result="handleImage(event)" url="change.xml" method="POST">
                  <mx:request xmlns="">
                      <dataDumping>
                          {dataDump}
                      </dataDumping>
                  </mx:request>
              </mx:HTTPService>
          This pulling data from the XML file where i plan to store the frame that needs to be displayed on of the SWF file.
          I checked that the HTTP service was working by using the function
                      private function handleImage(event:ResultEvent):void
                          img1.source = event.result.imagelocation;
          And as i expected when i change the xml file, the image changes.
          However i created a variable
          private var i:String = "test";
          And planned to have the HTTP service change the value of this value. I assumed it would be the same code as what i previously used,so used the following code
                          var i = event.result.imagelocation;
          However using this, it dosent update the value of the variable being displayed in the text box,
          <mx:Text x="817" y="10" text="Total: {i}" width="157"/>
          Can anyone see where i am going wrong ?
          • 2. Re: SWF Loader and MovieClip problems
            David_F57 Level 5
            hi,
            first declare the var as bindable
            [Bindable] private var myText:String
                            myText = event.result.imagelocation;
            <mx:Text x="817" y="10" text="Total: {myText}" width="157"/>
            David.
            • 3. Re: SWF Loader and MovieClip problems
              djh88ukwb Level 1
              David thanks yet again ! You have helped me out yet again Thanks alot.
              Could i ask if its possible to create a function, that when you click it, it increments a value by 1 and then saves that value to the XML sheet.  So when it is clicked a second time, it takes the value from the XML sheet, adds 1 and saves it back to the XML sheet.
              I need to figure out how to do this, in order for the Next and Previous buttons to work on the following code.
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" applicationComplete="load()">
                  <mx:Script>
                      <![CDATA[
                          import mx.rpc.events.ResultEvent;
                          [Bindable] public var dataDump:String = "datadump";
                              flashMovie.gotoAndStop(myText)
                              getImage.send();
                              setTimeout(load,1000);
                              myText = event.result.framelocation;
                  </mx:Script>
                  <mx:SWFLoader id="loader" source="flash.swf" complete="initMovie()" x="-9" y="-3"/>
                  <mx:Button label="Next" click="flashMovie.nextFrame()" x="78" y="405"/>
                  <mx:Button label="Previous" click="flashMovie.prevFrame()" x="0" y="405"/>
                  <mx:Button label="4" click="flashMovie.gotoAndPlay(7)" x="156" y="405"/>
                          <dataDumping>
                              {dataDump}
                          </dataDumping>
                      </mx:request>
                  </mx:HTTPService>
              </mx:Application>
              I need to be able to create a function that increments by one everytime the next button is clicked.  I know i will have to use a php script to alter the actual XML file, but im not sure on creating the flex side of things.
              If you could help i would be most thankful
              • 4. Re: SWF Loader and MovieClip problems
                David_F57 Level 5
                hi,
                have a look at this code, it works differently to what you have described, but it may give you some idea's
                http://gumbo.flashhub.net/imgmenu/ - source included
                David
