6 Replies Latest reply on May 14, 2010 5:57 AM by hans-g.
    Text Alignment (Spry, CSS) Problem
    Barna.S
      I started to create a site containing 3 spry under each other.
      In the Tab of the Spry collapsible panel there is a table now with two columns.
      In the first column there is an image, in the second one I started to type.
      After I hit return and want to start a new row, the top left alignment of the table do not work.
      I also tried to find something in the CSS of the Collapsible panel with no success.
      Could you let me know where I could find something about it on the internet, what can be the problem?
      Thank you!
        • 1. Re: Text Alignment (Spry, CSS) Problem
          hans-g. Adobe Community Professional & MVP
          Hi Barna,
          it would be easier for me (and for a helpful assistance) if you could give me a link to your website. Without seeing the page, it's harder (for me) to offer help.
          Hans-G.
          • 2. Re: Text Alignment (Spry, CSS) Problem
            Barna.S Level 1
            This is the URL:
            http://web.t-online.hu/sipos4/
            it is a draft only, and the previously attached picture was the result of the second try.
            I rarely use Dreamweaver so maybe I just missig some basic thing when I building the site.
            Thank you for the help!
            • 3. Re: Text Alignment (Spry, CSS) Problem
              Hi Barna,
              that's only a first reflection for you: don't you believe all your measures are a little too large:
                  <table width="2500" border="0">
                    <tr>
                      <td width="450"><img src="pics2/chocolatepudding.jpg" width="450" height="85" /></td>
                      <td width="2040" align="left" valign="top"><p>with 70% Brasil cocoa</p>
              ---------------------------deleted-------------------------
                    <tr>
              What do you think about 1024 px or 100%?  Your panels are working well, what I can see at my first glance, anyway.
              After I come back from town, let's take again (and if possible with some smaller table width), ok?Hans-G.
              • 4. Re: Text Alignment (Spry, CSS) Problem
                Hi Barna,
                back from town, I've experimented a little bit with your homepage without changing your template too much. I like that game like you did (only a draft). The result I can present here: http://www.goldschmiede-blumberg.de/AdobTest/sispos4/index.html. Ok, I attached two missing images.
                I must admit, the broad panels have their charms, I like them. And now it's up to you to build your own individual viable "Barna project".Good luck, Hans-G.
                • 5. Re: Text Alignment (Spry, CSS) Problem
                  Barna.S Level 1
                  Hi Hans-G,
                  it was suprising you sacrificed your time to build the whole webpage again!
                  Yes, I will think about it again if I will use these broad panels or not. Im not sure about the measures neither, maybe 400px height would be enough for the pictures.
                  I check it only on my computer which has the resolution 1902x1200, so it seems to me quite small already.
                  thanx for the help, and I'll check your codeing.
                  Barna
                  • 6. Re: Text Alignment (Spry, CSS) Problem
                    Hi Barna,
                    yesterday in Germany we celebrated a so-called Father's Day. It was such a rainy day, so we stayed at home and I was allowed to spent a little bit of my time on playing with DW and your nice website.My congratulations on your monitor! The mine has 20 ", anyway, and I use a 1280 x 1024 resolution. But it seems my family will please me with a bigger monitor (yeah, Christmas is not far!).
                    Apropos, a good indication about common browsersizes you will find here: http://browsersize.googlelabs.com/. Try it please.
                    Good luck, Salü
                    Hans-G.
