1 Reply Latest reply on May 12, 2010 9:27 AM by quentin-lanotice
    Introspection problem, Tomcat in cause ?
    quentin-lanotice
      Hello,
      I'm curently using FB 4, I'd like to create a connexion between FB4 and my Mysql database but even with all my efforts I can't manage to make work Zend Framework, it always bug during the introspection.
      I'm wondering if Tomcat is in cause, maybe I should use EasyPHP. I really don't know what to do next so please help me.
      amf_config
      [zend]
      ;set the absolute location path of webroot directory, example:
      ;Windows: C:\apache\www
      ;MAC/UNIX: /user/apache/www
      webroot =C:/Program Files/Apache Software Foundation/Tomcat 6.0/webapps/usr/TutorielsInterface
      ;set the absolute location path of zend installation directory, example:
      ;Windows: C:\apache\PHPFrameworks\ZendFramework\library
      ;MAC/UNIX: /user/apache/PHPFrameworks/ZendFramework/library
      ;zend_path = C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\usr\TutorielsInterface\ZendFramework\library
      [zendamf]
      amf.production = false
      amf.directories[]=./
      gateway.php
      <?php
      ini_set("display_errors", 1);
      $dir = dirname(__FILE__);
      $webroot = $_SERVER['DOCUMENT_ROOT'];
      $configfile = "$dir/amf_config.ini";
      //default zend install directory
      $zenddir = $webroot. '/ZendFramework/library';
      //Load ini file and locate zend directory
      if(file_exists($configfile)) {
      $arr=parse_ini_file($configfile,true);
      if(isset($arr['zend']['webroot'])){
      $webroot = $arr['zend']['webroot'];
      if(isset($arr['zend']['zend_path'])){
      $zenddir = $arr['zend']['zend_path'];
      // Setup include path
      //add zend directory to include path
      set_include_path(get_include_path().PATH_SEPARATOR.$zenddir);
      // Initialize Zend Framework loader
      require_once 'Zend/Loader/Autoloader.php';
      Zend_Loader_Autoloader::getInstance();
      // Load configuration
      $default_config = new Zend_Config(array("production" => false), true);
      $default_config->merge(new Zend_Config_Ini($configfile, 'zendamf'));
      $default_config->setReadOnly();
      $amf = $default_config->amf;
      // Store configuration in the registry
      Zend_Registry::set("amf-config", $amf);
      // Initialize AMF Server
      $server = new Zend_Amf_Server();
      $server->setProduction($amf->production);
      if(isset($amf->directories)) {
      $dirs = $amf->directories->toArray();
      foreach($dirs as $dir) {
          // get the first character of the path.
          // If it does not start with slash then it implies that the path is relative to webroot. Else it will be treated as absolute path
          $length = strlen($dir);
          $firstChar = $dir;
          if($length >= 1)
          $firstChar = $dir[0];
          if($firstChar != "/"){
          // if the directory is ./ path then we add the webroot only.
          if($dir == "./"){
          $server->addDirectory($webroot);
          }else{
          $tempPath = $webroot . "/" . $dir;
      $server->addDirectory($tempPath);
      }else{
         $server->addDirectory($dir);
      // Initialize introspector for non-production
      if(!$amf->production) {
      $server->setClass('Zend_Amf_Adobe_Introspector', '', array("config" => $default_config, "server" => $server));
      $server->setClass('Zend_Amf_Adobe_DbInspector', '', array("config" => $default_config, "server" => $server));
      // Handle request
      echo $server->handle();
      My php file is at the root : C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\usr\TutorielsInterface\TutorielsInterface.php
      Of course Tomcat is running but when I try to launch the introspection I get an error even when I try to generate a sample... The error tell me to check amf_config and then the code which follow, which is a part of gateway.php :
      false), true);$default_config->merge(new Zend_Config_Ini($configfile,  'zendamf'));$default_config->setReadOnly();$amf = $default_config->amf;//  Store configuration in the registryZend_Registry::set("amf-config", $amf);//  Initialize AMF Server$server = new  Zend_Amf_Server();$server->setProduction($amf->production);if(isset($amf->directories))  { $dirs = $amf->directories->toArray(); foreach($dirs as $dir) { // get  the first character of the path. // If it does not start with slash then it  implies that the path is relative to webroot. Else it will be treated as  absolute path $length = strlen($dir); $firstChar = $dir; if($length >= 1)  $firstChar = $dir[0]; if($firstChar != "/"){ // if the directory is ./ path then  we add the webroot only. if($dir == "./"){ $server->addDirectory($webroot);  }else{ $tempPath = $webroot . "/" . $dir; $server->addDirectory($tempPath); }  }else{ $server->addDirectory($dir); } }}// Initialize introspector for  non-productionif(!$amf->production) {  $server->setClass('Zend_Amf_Adobe_Introspector', '', array("config" =>  $default_config, "server" => $server));  $server->setClass('Zend_Amf_Adobe_DbInspector', '', array("config" =>  $default_config, "server" => $server));}// Handle requestecho  $server->handle();
