7 Replies Latest reply on Jun 10, 2010 6:41 AM by uzairseedat
    Image update problem
    uzairseedat
      I have an image control in my application which loads an image from the assets folder. Then I use FileReference object to browse and upload the image to a service. The service replaces the image with same name and extension in the assets folder. Finally I try to load the image again but it keeps on showing the previous one. However, when I run the application again, the new image is loaded. How do I get the latest image to show up as soon as the upload is finished?
        • 1. Re: Image update problem
          David_F57 Level 5
          hi,
          this is what the upload and return should look like
          private var fr:FileReference = new FileReference();
          private function uploadimage():void {
          fr.addEventListener(DataEvent.UPLOAD_COMPLETE_DATA,onUploadCompleteData);
          fr.upload(myURLRequest);
          private function onUploadCompleteData(event:DataEvent):void
          fr.removeEventListener(DataEvent.UPLOAD_COMPLETE_DATA,onUploadCompleteData);
          downloadimage();
          David
          • 2. Re: Image update problem
            uzairseedat Level 1
            This is code I currently have in my Cairngorm Command that is reponsible for the upload operation:
            protected function uploadLogo():void
                        try
                            var urlRequest:URLRequest = new URLRequest("http://localhost:2333/FileUploader/upload.ashx");
                            this.fileReference.addEventListener(DataEvent.UPLOAD_COMPLETE_DATA, updateLogo);
                             this.fileReference.upload(urlRequest);
                         catch(error:Error)
                    protected function updateLogo(e:DataEvent):void
                        this.fileReference.removeEventListener(DataEvent.UPLOAD_COMPLETE_DATA, updateLogo);
                        var app:Application = this.parentApplication as Application;
                        var siteLogo:Image = this.parentApplication["imgLogo"] as Image;
                        siteLogo.load("assets/images/logo.jpg");
            • 3. Re: Image update problem
              David_F57 Level 5
              hi,
              do you have a load complete event for the image, you need to refresh the image once it has loaded the new data.
              David.
              • 4. Re: Image update problem
                uzairseedat Level 1
                I cant find Load_Complete event on image. Could you plz specify the exact event I should work upon? Thanks in advance.
                • 5. Re: Image update problem
                  uzairseedat Level 1
                  Even I've tried using a Java servlet for this and the result is same
                              try
                                  var urlRequest:URLRequest = new URLRequest("/FrontApp/FileUpload");
                                  this.fileReference.addEventListener(Event.COMPLETE, updateLogo);
                               catch(error:Error)
                                   Alert.show("Unable to upload logo to server","Error", Alert.OK, null, null, model.errorIcon);
                          protected function updateLogo(e:Event):void
                              //fetch site logo
                              this.imageLoader= new Loader();
                              var imageRequest:URLRequest = new URLRequest("assets/images/siteLogo.PNG");
                              this.imageLoader.contentLoaderInfo.addEventListener(Event.COMPLETE, loadImage);
                              this.imageLoader.contentLoaderInfo.addEventListener(IOErrorEvent.IO_ERROR, loadFailed);
                              var context:LoaderContext = new LoaderContext();
                              context.applicationDomain = ApplicationDomain.currentDomain;
                              this.imageLoader.load(imageRequest, context);
                        protected function loadImage(e:Event):void
                              if(this.imageLoader.content)
                                  model.siteLogo = this.imageLoader.content as Bitmap;
                  • 6. Re: Image update problem
                    UbuntuPenguin Level 4
                    He's probably referring to the EVENT.COMPLETE found here
                    http://livedocs.adobe.com/flex/3/langref/mx/controls/Image.html#eventSummary
                    • 7. Re: Image update problem
                      uzairseedat Level 1
                      Hmm... but if you observe my latest reply above, I've already used it. The thing works perfect except that I need to clear my browser cache once when the application is running. After that, the image updates itself perfectly.
