2 Replies Latest reply on May 12, 2010 6:06 AM by snuttypuff
    simple 'hollow' lines.
    snuttypuff
      Hello,
      I need to create a flow diagram with hollow lines, like pipes, in 2d like this: pipes example.jpg
      is there an easy way to do this?
      Many thanks,
      Snutty
        • 1. Re: simple 'hollow' lines.
          Junk Mailer Level 3
          Use a double stroke where one stroke is slightly wider than the one
          above it in the stacking order.
          Go to the Appearance panel and click the options flyout in the upper
          right corner. Select "Add New Stroke". Repeat again (if you don't
          already see two strokes) so you now have 2 strokes in the Appearance
          panel. Select the bottom-most stroke and choose black as your stroke
          color, then adjust the stroke weight from the Stroke panel so that it
          is slightly wider than the one above it. Now select the top-most
          stroke from within the Appearance panel and select the appropriate
          color to represent water, steam, gases, etc.
          Make sure and drag the result into your Graphic Styles panel for easy
          access later as you draw.
          -JM
          • 2. Re: simple 'hollow' lines.
            snuttypuff Level 1
            Perfect.
