Recently I recorded someone playing the guitar. I used a Canon XL2 with a lavalier mic. I recorded into audio 1/3 otherwise mono. In the past when I used final cut, I had the option to change the audio from 90% on the left channel and 10% on the right to a 50/50 each side. This improved the audio quality output. I am looking for a way to adjust the balance? I clicked on the audio mixer and no luck.
For this sort of Balance, I would Rt-click and choose Edit in Audition. Now, if you do not have Audition, or have it set up to handle WAV files, you should have Edit in Soundbooth. You will have much more control in those programs.
