3 Replies Latest reply on May 12, 2010 10:00 AM by Wade_Zimmerman
    CS5 Crop marks don't work in Save For Web
    luchababe Level 1
      I'm playing in the trial version of Illustrator 5.
      I'm having trouble figuring out the crop marks.  I select an object and try the various versions of creating crop marks.  But when I Save For Web, it does not use the crop marks as a guide to trim the artwork down.  The crop marks are visible.
      In CS3, which I've used for years, I would create an object and use the crop mark tool to create the marks at the size of my object.  When I would Save For Web it would save the file to the exact size of my crop marks, no matter if I had artwork in clipping masks that go outside the crops.
      Why does this not work in CS5?
        • 1. Re: CS5 Crop marks don't work in Save For Web
          I think you got it all wrong. The crop marks effect is just that - an effect that creates some renderable objects for output. it never was any different. If you are referring to the former crop tool, then that is now artboards and the optionjs to use them must be ticked in whatever exporters and savers you use. Still, for web output it's not really the most efficient method, you would do that with slices, which can exist without affecting your initial art. But they are already in CS3, so I'm wondering why you nbever used that method in teh first place...
          Mylenium
          • 2. Re: CS5 Crop marks don't work in Save For Web
            luchababe Level 1
            In CS3, I would create a square shape around the image I want to Save For Web.  I would select the Crop tool, set it to Object and it would create the crop around my selected object.  When I Saved For Web, it would only save the artwork within the crop marks.  Now in CS5 I seem to have to do extra steps to get it to do the same thing.  I have to make my square, turn that square into the artboard, the Save For Web and check the Clip to Artboard under image size.  When I'm done, I go back to the art work and Undo until the artboard is back to my working size.  Not very convenient with my work.  I use Save for Web all the time to save pngs with transparent backgrounds, either as single files or as layers for animations.
            • 3. Re: CS5 Crop marks don't work in Save For Web
              Wade_Zimmerman Level 6
              You do speak the truth so in CS 4 and now Cs 5 you instead of drawing a rectangle and the making it into crop marks you simply draw an artboard then when you export you select to use artboards in the export dialog  and select the artboard you just made and voilá.
              Now before you go crazy this is an advance you can also choose to export all the artboards a range of artboards or a non-contiguous selection of artboards this way.
              the difference here is that you draw the artborad which is actually drawing a rectangle and making the crop marks as in the CS 3 all in one opertation
              it is really the same feature with lots of features added to it. Including the ability to name the art boards (cropped areas) number them reorder them
              manage them in the artboard panel and then the team went farther than that with pasting in place pasting an element on all the artboards at once.
              It is really just the crop area feature but with lots of possibilities.
              If you need t draw an artboard within another artboard hold down the shift key.
